Question about Vacuums
Power goes on and off. - Vacuums
    Problem Solver:
  • 6 Answers
It could be three different things- or one or more of these three, but more than likely just one.
1- a bad cord or plug end
2- a bad switch
3- a motor brush is losing contact due to poor pressure due to the carbon brush being worn- of the two motor brushes, their length is normally sufficient to last for years with trouble free service. However, if a vacuum is neglected, as in the filters never cleaned or replaced ( use 10/ $2.99 electrostatic register vent filters from any home store's furnace filter section. Cut to fit, and in the case of the Hepa filters, if you have a dusty family you'll go broke changing these so just cut your electrostatic ones and maybe stack a layer or two, but since they are cheap be liberal and change often). What happens with dirty neglected vacuums is they overheat causing the motor brushes to glaze the copper commutator they ride on and eventually wear out the carbon. The added brush dust cakes up and acts as an abrasive.
Alright, so it's not an issue of neglect or jerked on cords? Well, unfortunately several manufactures have lately installed somewhat inferior switches on their vacuums by way of saving a few cents in manufacturing costs. The amperage ratings on the switches are rated just above the typical 12 amp motor ratings on the vacs motor. In real world use though the strains of suction resistance and cord resistance caused by ultra thin copper wire in the cord add up to extra heat at the switches terminals. The plastic in the switch will get very hot as you vacuum and when you flip the switch off each time you finish vacuuming it literally shifts the switching contacts into positions a little more distorted from their original setting. Arcing is the next thing that happens and then its a heated plug end.
That's the story of how a vacuum cleaner works when it's stressed and strained. Ironically when all of this goes on the bearings also overheat due to the arcing motor brushes. And because the belt for the roller is on this motor as well, when you shut the vac off the belt will heat up and even melt slightly. Then when you go to vacuum again the belt will vibrate causing more damage...
This is why bag vacuums are better.
Better yet, get a Rainbow D4 and ALWAYS ALWAYS ALWAYS spin the separator by hand to assure the brushes are not sticking before powering it up. The D4 is the best vacuum ever made. The Eureka Vibragroomer is the best upright ever made.
Posted on Oct 07, 2009
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
Dont know where a wire goes in my vacume
ok,That makes two of us. :) What color is the wire? and where is this wire located? I'll try to help. Ned
Jul 31, 2014 | Hoover Vacuums
Riccar 8955 power cord schematic
The black wire goes to the switch, the white cord goes to the white wire in the vacuum.
Feb 14, 2014 | Riccar 8955 Upright Vacuum
My beam Q100 power brush starts for about 5 seconds then stops power.
Take the brush out and check for hair & string around the ends where it goes into the bearings. Remove the crud and reassemble. NEVER oil the bearings. It will collect dirt and dust and gum up.
Jan 18, 2013 | Beam Q power Brush Q100
My electrolux ambassador power head goes on and off as I try to sweep. What can I do?
Most probably the hose has gone bad. You would new a new one. this will fit your vacuum
http://www.ezvacuum.com/electrolux-hose-with-switch-control-for-electrolux-canister-vacuum-vnotch-generic-p-1525.html
Jan 11, 2013 | Electrolux Vacuums
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
Hoover power drive u6311 - How do u change switch? Does anyone have any idea how to remove the on and off switch, when I tap on the housing the motot and light goes on and off. Also does somebody have a...
The swrtch is located in the bottom section of the motor. When the swtcih goes out it time to repalce the unit. The swtich is part of the motor. The switch rod run all the way down the body to the swtich located in the motor.
May 23, 2009 | Hoover U6311-930 Power Drive Bagged...
Wiring schmatic for kenmore canistar vacuum
Generally, there are two wires inside the unit which connect to the wiring going down the suction hose.  Since the unit is a/c...it doesn't matter which of them goes to which terminal.  The wires are switched in some cases.  Look for the open terminal.
Dec 19, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Miele Blue Moon vacuum has no power
It can be various problems, the cord reel contacts or cord may be bad, You didn't give the model number, but alot of Miele's have a speed control that goes bad. It will have to taken aprt and checked.
Jan 31, 2008 | Miele Blue Moon Bagged Canister Vacuum
Vacuums Logo
171 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
