Question about IBM Keyboard, TrackPoint
The B key's patch comes off, how to put it back
Remove the red button, place a bit upward and pressed down carefully
Posted on Oct 08, 2009
How to Patch a Bicycle Tube?
buy a new tube.
Pull out tube
Pump air in to it
put under water
notice were are leaks from
using a bicycle patch kit
sand tyre around hole
glue patch over hole
wait for glue to set
check no nails, glass embedded in tyre first before you
put tube back inside tyre
put tyre back on wheel
https://www.youtube.com/watch?v=x5x7GIc0e6g
https://www.youtube.com/watch?v=WG7Y1eSDsNA
Oct 20, 2016 | Cycling
Tip
Patching a hole in drywall/sheetrock
The best way to patch a hole when you don't have backing material is as follows:
Step 1: Cut the hole out square with a keyhole saw or utility knife:
www.all-wall.com/s.nl/sc.11/.f?search=keyhole+saw
Step 2: Cut a piece of drywall, (the same thickness as the wall that you are working on), to fit fairly tightly into square hole. (HINT: You don't want the patch to fit so tight that it breaks the corners when you try to put it in.) If done properly, this patch will not want to stay in the hole by itself. You must leave 1/32nd of an inch all the way around the patch. Once the patch has been properly fitted, you are now ready to start taping it in.
Step 3: Put the patch face down on the floor or table so that you can easily work on it. Using drywall mud/compound & the 5" knife, lightly mud the back side of the patch (www.all-wall.com/Categories/Joint-Knives/Hyde-Stainless-Hammer-Head). Place a piece of drywall tape over the patch, allowing it to hang over the edge of the patch about 1 1/2" on the top/bottom of the patch (paper tape flaps).(www.tooldistrict.com/2inx500ftpaperjointtapepn500bypermaglas-mesh.aspx) Holding the tape firmly against the patch, wipe down the tape with the 5" knife.
Step 4: Once the piece of tape is wiped down, you are now ready to apply mud to the section of wall where the paper tape flaps will be laying. Place the patch over the hole, tapping it into place until the patch is laying flat on the wall. Holding your fingers on the seams of the patch, wipe down the first paper flap, and then the other. (HINT: Always wipe down the top flap first, then the bottom flap. Make sure the patch is flush with the wall, or recessed slightly. If the patch is sticking out from the wall even a little bit, it will be very difficult to hide!)
Step 5: Now that the patch is in, mud the horizontal seams in, paper tape, and wipe down. Repeat the process for the vertical seams. (NOTE: You may use mesh tape on these seams if you wish because mesh is a little thinner than the paper tape; making it a little easier to cover on the next two coats. Don't make a special purchase if you don't already have some laying around, it's not worth it. ( www.all-wall.com/Categories/Fiberglass-Mesh-Drywall-Tape/Thin-Drywall-Mesh-Tape )Let this dry for 12 hours before coating again.
Step 6: For the next coat you will need a 10 " broad knife (www.all-wall.com/Categories/Taping-Knives-Stainless-Steel/Hyde-Maxxgrip-Extruded-Back) Apply mud to the patch, covering the tape from the previous application.You will need to leave more mud around the outside of the patch; not too much on top of the tape. It is already going to be a little high on top of the tape so you are basically creating an optical illusion by building up around the patch. Let this coat dry 24 hours.
Step 7: If the 2nd coat was done properly, then putting a finish coat, (3rd and final coat), won't be a problem. This coat is just to fill in any low spots that you weren't able to get completely full the last coat. And if you did get it full the last time, congrats, then it is just a skim coat to fill in any air bubbles that may exist. (NOTE: Whenever patching over an already painted wall, the drywall mud/compound will bubble. This is normal. After 2nd coat of mud drys, scrape off the air bubbles before applying the next coat.) Let this coat dry for 12-24 hours
Step 8: Now the fun part begins: Use a sanding sponge or a sanding pole to sand the patch off, (http://www.all-wall.com/acatalog/A000_Dustless_Sanding_20.php). Then it is ready for paint!!
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power-HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing, but as you can see, just a simple patch is very involved. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Jim
Key Words: Drywall/Sheetrock/Gypsum Wallboard, Patching, Texturing, Speckling, & Paper Tape
on Dec 01, 2009 | Hand Tools
I have a 2012yahama zuma and i locked the ignition keys under the seat. How can I open the seat without a key? THX
I'm not sure (don't own a Zuma) but maybe if you remove the front panel, in front of the seat you may have access to the bolts that hold on the hinge to the seat. If you can unbolt the hinge then just flex the seat up and work your hand under there.
(worst case scenario), take off the front panel, drill a hole in the underseat bucket, and get key, patch hole, get new key cut
At least if you need to tear into it, do it where nobody can see it.Once you patch the hole, put a ZF sticker over the patch
Jul 15, 2015 | Motorcycles
How do you fix a leak in a towable?
get a patch kit at walmart or any lowes..it comes in a kit w/glue and sometimes a patch..follow the instructions. glue then put patch on ..use the right time in instructions though
Aug 16, 2011 | Sport & Outdoor - Others
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
Tear on bottom of seat of jeep jogging stroller , wondering if I can iron on a patch??
First I would use some fabric glue (you can get it in the craft or fabric stores) then I would put a patch on it to cover the damaged part and make the fabric stronger. Some of the iron on patches are not very strong and they start to come off. Maybe just glue on a patch with the fabric glue.
Sep 26, 2009 | Jeep Liberty Limited Urban Terrain Jogger...
I have a 4700 with a creative x-fi card. The
you need to either
1. uninstall the MS patches.
2. locate the patch which is causing the issue ( you can use, selective login for this)
3. or you can put latest patch from Dell/creative for the creative sound card
Sep 09, 2009 | Dell Dimension 4700 PC Desktop
Small rip in treadmill belt
No really. You need to replace the entire walking belt. Not to hard of a job and most replacement belts come with some instructions. We use www.treadmillpartszone.com for parts.
Apr 10, 2009 | NordicTrack E4000 Treadmill
Generic host win32 services problem
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the above patch solution and the following windows update solution works only on PC/computer running genuine Windows and not pirated versions):
  • Go to the start menu
  • Right click “My computer”
  • Click “properties” then the “automatic updates” tab
  • Choose “turn off automatic updates”
  • Restart your computer
  • Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
  • Manually update windows
  • Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
  • Go to Run and type regedit
  • Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Services >> Browser >> Parameter
  • look for the key IsDomainMaster
  • Set its value to False
  • Restart the computer
Jan 22, 2009 | Microsoft Windows XP Media Center Edition...
IBM  Keyboard, TrackPoint  Logo
29 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
