Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
Windows XP - need to restart Wireless Zero Configuration
About 50% of the time I start my computer runing Windows XP Home, I have no wireless internet automatically started so I run Serices.msc, then reset Wireless Zero Configuration to automatic then restart it. How can I set Wireless Zero Configuration so it starts automatically?
thanks, Kai
  • 330 Answers
Type this in command window sc config wzcsvc start= auto
Posted on Oct 07, 2009
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
Tip
How to restart Wireless Zero
Like any other service, sometimes the Windows Wireless Zero service needs to be restarted. It could be because of a glitch or error, or it could be because a third-party utility (such as the Dell WLAN application) stopped it. In any event, restarting Wireless Zero and getting Windows to automatically see and manage your wireless connections is a breeze. (If you have a third-party program managing your wireless connections, you'll either need to stop that program or uninstall it before restarting Wireless Zero.)
A. On the Start menu, right click on My Computer (in Vista, it's just called Computer) and select Manage.
B. When the Computer Management console opens, click the plus sign next to Services and Applications to expand that section.
C. Click on Services.
D. Scroll down the list of services until you find Wireless Zero Configuration, and click on it. (It may help to maximize the window.)
E. Toward the top of the window, under Wireless Zero Configuration, you'll see either Start or Restart underlined; whichever one it is, click on it.
F. Close the Computer Management console.
G. Right click on the Windows wireless icon in your system notification tray and choose View Available Wireless Networks.
H. Click Change advanced settings on the left side.
I. Go to the Wireless Networks tab and put a check in the box marked Use Windows to configure my wireless network settings.
J. Click OK.
The list of available wireless networks should automatically refresh itself, and you should be able to connect to any network you could connect to before (as long as you have the proper keys and credentials).
on Oct 06, 2010 | Computers & Internet
Advanced configuration settings for the Belkin wireless G Plus mimo network adapter
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 22, 2013 | Belkin F5D9050 Wireless G Plus MIMO USB...
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
Cant access wireless network
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
I have F5D7234-4V1 with insight internet connection and i have win-xp laptop , ERROR MESSAGE - (windows cannot configured wireless ) tell me what to do - But unable to start WZC on my computer
If you want to use Windows Wireless Zero Configuration to manage the wireless network, you will need to have Windows XP with service pack 2 as a minimum.
With Windows XP and SP2, you will need a Microsoft update for WPA2 that can be obtained from:
http://support.microsoft.com/kb/893357/en-us
After installation you will need to use the Windows Zero Config wireless configuration in the control panel to configure the adapter. WPA2 should now be available and work correctly.
Windows XP with Service Pack 3 and Windows Vista offer support for WPA2 without additional updates.
Nov 04, 2010 | Belkin F5D7234-4 Router
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
Unable to connect to wireless internet
You may need to start the wirless zero configrations...
you havnt mentioned your OS..
any ways here is the way to turn it on...
for WIN XP
Windows XP Windows XP users must have Service Pack 2 installed to activate the Wireless Zero Configuration. ( How do I check that? )
  • Go to Start and Control Panel
  • Click on Administrative Tools and Services
  • In the Services box scroll down the list of Services (Local) until you find the one labelled Wireless Zero Configuration and double click it.
  • In the Wireless Zero Configuration Properties (Local Computer) box change the Startup type to Automatic
  • Click on Start and once the service has started click on OK
  • Now find the service labelled WLAN AutoConfig and double click on it
  • In the WLAN AutoConfig Properties (Local Computer) box change the Startup type to Automatic
  • Go to File and Exit to close the Services window
Windows Vista
To start Wireless Zero Configuration in Windows Vista you need to log in as an Administrator.
  • Click on Start and Control Panel
  • Select Administrative Tools and then Services
  • In the Services box scroll down the list of Services (Local) until you find the one labelled Wired AutoConfig and double click it.
  • In the Wired AutoConfig Properties (Local Computer) box change the Startup type to Automatic
  • Now find the service labelled WLAN AutoConfig and double click it.
Let me know if it helps...
rate me .....
Best regards
Tanveer Ahmad Khan
Dec 14, 2008 | Acer Aspire 3680 Laptop
Windows configuration zero
To get to the Windows Zero Configuration settings in Windows XP:
Right click on My Computer>>Manage>>Double click on Services & Applications>>Applications.
Scroll down and right click on Windows Zero Configuration>>Properties. Make sure your start up type is Automatic and that the Service Status is Started. I hope this helps!
Sep 23, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
236 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
