Question about Car Audio & Video
Bridge two 12inch subs together
I want to know which way is better two connect the wires on two 12inch subs together
  • 36 Answers
It depends. what is the ohm rating of each sub, and the amp. are the subs DVC(dual voice coil)? and are you trying to bridge them directly to the amp? i need more info, but i can say that if they are 4ohm subs, if you run them parallel, they will become 2 ohm. to keep them at 4 ohms, they need to be run i n series, and you need more than 2 for that.
Posted on Oct 07, 2009
How do I wire my special edition 12inch sub in the box to a single output amp
Well its a single channel prolly 400watt 2ohm check and see if the speaker has two separate sets of wire on each side of the speaker if so bridge it and connect it to that channel then you should be Good to go
May 25, 2015 | Car Audio & Video
Hi there i have just purchased two newer model type r alpine subs and a week ago i got a great deal on a rockford fosgate 800 a2 amplifier. The amp has two outputs and don't know exactly what ohms are at...
if you bridge it i believe you run at 4 ohms instead of 8 even if the subs are wired together i would not bridge it for fear of blowing the subs. if you where to bridge it it would be the left channel on one terminal and the right on the opposite terminal. but i highly advise against bridging it as they are wired together. its running at the proper impedence NOT bridged.
Mar 14, 2011 | Car Audio & Video
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
How 2 bridge tha opti drive 1222d 12inch subs 2 the opti 600x2hc
You can check Both Crutchfield's learning center on subwoofer wiring diagrams and www.the12volt.com with their wiring diagrams. The crutchfield setup will be more informative for this type of problem. Just go one of the + to one of the - on each sub then wire the other plus's together between the subs as well as the minuses like between the subs and use the open plus and minus that u didn't just bridge. Then there should be just 2 wires a plus and a minus to the amp. Then follow the amp bridge wiring which should be found right above the speaker terminals it will be left plus to right minus or the other way around
May 05, 2009 | Car Audio & Video
Wiring my 2 L7 with a kicker 1000times1
Run the subs in series then bridge the amp. So run the normal + to - to the one sub then hook up a spare wire (not connected to the amp) to the same + and - connections. Then run the spare wire to the + and - of the other sub. This will tie the 2 together so you can bridge the ampfor more power instead of using 2 seperate channels.
Feb 01, 2009 | Kicker 02S10L74 Car Subwoofer
Bridging
What type of subs are they? Single or dual voice coils? 2 ohm or 4 ohm?
May 26, 2008 | Kenwood KAC-7252 Car Audio Amplifier
Amp. Audiobahn a2300hcx
If the subs are dual 4 ohm voice coils and if your amp is good down to 1 ohm, your best bet is:
  1. Connect the voice coils in parallel ("+"s together, "-"s together). This will make the impedance of each sub 2 ohms.
  2. Connect the subs in parallel.
  3. Bridge the amp to one channel.
This should max the amp out at 2400W, which means about 1200W per sub.
If your subs are single 4 ohm voice coils, do the same steps, but you'll only be able to load the amp to 2 ohms, which means about 600W per sub.
Also keep in mind that box size, type, and quality make a big difference in how subs sound.
Mar 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
206 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
