Question about HP Pavilion dv6810US Notebook
How to check that the sound card is not loose
I need to know how to check that the sound card is not loose can someone guide me through it or show me the manual that describes the position of the sound card so i can check it is not loose
  • 1 more comment
  • barakzai7 Oct 07, 2009
    i tried this but sometimes it works and sometimes it doesn't so i thought it was loose if that is the case does it mean my sound card is damaged
  • barakzai7 Oct 08, 2009
    thk u very much but if its part of the motherboard then it must be broken thanks for the help
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
On laptops these days use builtin soundcards that are on the motherboard.
nothing should be loose.
there should be a chip labeled Conextant Audio , that would be the sound chip
Posted on Oct 07, 2009
Testimonial: "very helpful"
  • 788 Answers
The sound is built into your motherboard on all DV6000 and DV9000 units.
If you are not recving. quality sound, you may need to reload your sound drivers.
This unit is a DV6810us and should be running VISTA home 32.
If so, you can reload your sound drivers and others by simply Typeing recovery manager and continue, next go to advanced and choose re-install hardware drivers.
I hope this helps you, have fun.
P.S remove any external devices before reloading or restoring.
Model number A1286. My mac cannot turn on when I try to turn it on it just sounds like its warming up but the screen is all black, what do I do?
This is a very unusual symptom of hardware failure. One or more of the following might be the cause.
The ribbon cable to the display has worked loose or its connection has otherwise become interrupted. This seems the most likely; most other problems would at least show a "gray" screen during startup.
The GPU (graphics card) has come loose or (very unlikely) has died.
If you (or someone you trust) are not comfortable opening it up and checking for loose connections, you can try taking it in to an Apple store for assessment, but this model is considered "vintage" and no longer supported.
Just for reference, I'll include a link to several videos which explain the breakdown process in detail. (http://www.powerbookmedic.com/manual.php?id=35) MacBook Pro 15 A1286 Repair Guide
Aug 24, 2015 | Computers & Internet
Turbo noise
I'm not positive (from the description) but you may be describing a loose clamp or torn hose. You should carefully check the related plumping that the charged air travels through (from the turbo, through the air cooler, then back to the intake. If you don't have an air-leak then I would check around the turbo. Check the waist-gate for seized linkage. If you need more information please write back and let me know, good luck.
Mar 08, 2014 | 2006 Chevrolet Silverado 3500
Whats the ticking sound all of a sudden?
It sounds like a collapsed hydraulic valve lifter- a part of yoiur valve train in the upper engine. You need to have it checked at a shop you trust I don't know of any oil additives that can cure this, although someone here may give you some advice.
Loose valve train noise is common on high-mileage engines, but if it is a collapsed lifter, I think you should have it checked.
A loose timing chain will make a rhythmic slapping sound, but the ticking you describe sounds more like it's in your valve train. Have someone check it.
Nov 02, 2011 | 1995 Buick Regal
No suction. upright position shuts off unit. Turning off brush bar shuts off unit. will only run in floor position but has no suction. no clogs found.
From what you've described, it sounds as though you may need to wash the filter. This video guide from the Support section of our website shows the correct way to do this:
http://www.dyson.com/support/help.asp?article=1463&product=DC17-ANIMAL
Although you've found no blockages, it's definitely worth checking again to ensure nothing has been missed. This simple step-by-step walkthrough shows all the areas you should inspect:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
If you've followed these steps and are still experiencing difficulties, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com. One of our experts will run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I'm having issues with Dell 1708FPt, it has lines in the background like something wrong with the video processor. even does it when whows the Dell Screen Test mode, showing red, green, and blue. the...
From what you are describing it sounds like there is an issue with the video card or the connection from the card to the monitor.
Try:
1. Checking the cable going to the Monitor. Try another cable if you have one.
2. After powering off the computer and remove and re-seat the video card.
3. Does the video card have a fan? Is it spinning? - overheating could be an issue. Check for dust on the fan as well.
4. Do you have a spare card you can use to test?
It could also be an issue with your motherboard, this would probably need to be replaced.
Feb 28, 2011 | Computers & Internet
Please check my sound card
install the drivers of your sound card to fix the problem
Jun 18, 2010 | Intel REALTEK nc-r150201 Network Adapter
Sound not coming out of speakers
just remove the cord from CPu...the sound cord and re-plug it and try the option line out or line in...
otherwise simple way is that...check wheter there is sound installed in Control panel under the add or remove program tab....
if not,then install the driver from *********** Board CD..
simple restart the PC it is required..
and for more queries post it on..
www.vk7.weebly.com
under the guest book..
i will sort it out as soon as possible..
Dec 04, 2007 | Manhattan 1100 Computer Speakers
HP Pavilion dv6810US Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
