Question about Epson Stylus RX650 All-In-One Printer
Rx650 chip reset and ink replacement pads
Anyone know how to reset chip? rx650 epson printer?
also replace inkpads?
can i do it myself? or does anyone know who does it in perth [south]
? thankyou
  • Epson Master
  • 1,113 Answers
No crack for 650.
Suite 20, Level 3, 1060 Hay St, West Perth WA 6005 is Epson W.A. or any epson dealer can fix.
Posted on Dec 24, 2007
No reset chip for RX650.That printer will run generic cartridges...no problem.I use them...cheap...........the pads I do not know about.id suggest calling Perth serrvice and see if they will tell you about the pads
Posted on Jul 20, 2008
My epson rx650 ink pad replacement.
Epson have there reset's pretty locked up, Agents have to register to gain axcess rights to software program tool that resets purge counter (waste count rset) , there are 7 pads in these printers just felt blocks that suck up ink and the electronic counter. all colours are mixed in felt so no draining guess you could wash them out but it is the counter that will stop you, wont go till reset. I have seen some after market ink chip resets but dont know if they work.
Epson about 6 months ago sealed up their tec support download system, now we have to identify agent and rep who is downloading the "eagle" software that is the Epson adj software that allows adjustment and reset of waste ink counter.
reseter link and another http://www.printercartridges.com.au/
Dec 06, 2007 | Epson Stylus RX650 All-In-One Printer
Tip
EPSON PRINTER INKPAD RESET COUNTER
There are issues on printers especially with epson is the dreaded error " PARTS INSIDE YOUR PRINTER IS AT THE END OF ITS SERVICE LIFE"<br /><br />This error is caused by a full ink pad or the ink pad reset counter needs to be reset.<br /><br />to resolve this, for north american customers you can download a program called the inkpad reset counter. this is the site: http:www.epson.com/ipr<br /><br />from there just fill out the required spaces then submit. install and follow the wizard. make sure that your printer does not leak because it means you need to replace the ink pads. and its another question.<br /><br />hope this works and help you out<br />
on Jul 15, 2011 | Office Equipment & Supplies
What does alternate red and green flashing lights means
Ink pad full. Reset waste ink counter using epson resetter. Replace inkpad or extend the pipe of head cleaning mechanic to outside printer.
Jan 01, 2011 | Epson Stylus Photo 1290 InkJet Printer
My c86 printer is asking for a service can i over ride this as the print quality is still ok or can I service it myself. Dont want to buy another printer as i have many ink cartidges left
yes sure you can just download the inkpad reset utility at this website www.epson.com/ipr this driver will help you reset the counters of your printer just make sure you replace the ink pad itself. you can purchase the ink pads at best buy or at any nearby computer shop or you can use your imagination to replace that darn sponge
Sep 23, 2009 | Epson Stylus C86 InkJet Printer
Not works
You can reset the waste ink counter using
http://tricks-collections.com/2008/09/resetter-epson-c58-c67-c79-c90-r270-r390-rx650-cx3900/
The generic SSC utility is also available at
http://www.ssclg.com/epsone.shtml
However, remember ink is still accumulating in the waste ink reservoir and will eventually start to leak out. To replace the waste ink pads you need to disassemble the printer.
A free copy of the service manual is available at
http://www.filestube.com/2572254e26edfe0a03e9/details.html
Jan 31, 2009 | Epson Stylus Photo R390 InkJet Printer
Epson c70 problem
Re: Epson C70 Problem by Denny Conway (12/18/03 9:05 AM) reply + / - Aspah:A Service Error where all LED's/Lights are blinking at the same time,is normally a Maintenance Request Error, which is actually a Waste InkPad Overflow Error...JUST SO YOU WILL KNOW: On most Epson's, while theprinter is in this error condition, it disables all operations,including data communication. Normally your remedy is to replace theWaste Ink Pad/Pads with a new one/ones and then reset the InternalWaste Ink Pad Counter. If you just reset the counter and don't replacethe pads, then your printers old pads will eventually overflow andnormally start leaking ink out the bottom of your printer. You may wantto try doing a general search on the "fixyourownprinter.com" printerrepair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.You should be able to find quite a few references listed in the lastsix months and most included web-site links, for possible help on thereset procedure. Some also list links where you can purchase a SERVICEMANUAL, in case you want to try and do the service yourself...GoodLuck! Denny Conway...P.S. THIS INFO POSTED BY "WES" MIGHT HELP: Wes12/07/2003 13:57:30 To see what's involved in servicing the waste inkpads try this http://www.epsonhelp.web1000.com/wip.html ...IF you just want to reset the wate ink counter you can use this program http://inkjetprinterhelp.us/epsonSSC.html.Resetting the ink counter will stop the lights from flashing butcleaning/replacing the ink pads is recommended. ...OR... Tim H12/10/2003 2:46:24 Subject: Epson Reset Program Download Location.after a long search for a reset program for waste ink, without paying,i found it. goto: http://inkjetprinterhelp.us/sscserve.exe ...please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html ...p.s: this program has other features as well.
0.gif Re: Epson C70 Problem by Jim (12/21/03 4:10 PM) reply + / - I have just installed colour cartridges and a black cartridge into my C70.
Myproblem is that the black cartridge is not being recognised and I aminformed by the printer that there is insufficient ink in the cartridgeand a need a new replacement. The black cartridge that I have used is agenuine epson cartridge.
I have been informed by epson help linethat either I need to install a new new cartridge or that my printerneeds to go to Epson for a maintenance check.
I cannot afford another new ink cartridge nor can I afford the return charges and maintenance bill from epson.
Can you help?
0.gif Re: Epson C70 Problem by Wes t.gif (12/21/03 4:47 PM) reply + / - Theonly two option I can think of is to return the ink cartridge asdefective or you can trick the printer into accepting the cartridge.
Youwill need to download the SSC Service Utility and click on the "ResetCounters" tab and then click the "Reset Black" tab to reset the blackink cartridge. The only problem is you will need to reset or freeze theink cartridge.
You can get the SSC Service Utility here http://inkjetprinterhelp.us/epsonSSC.html
I hope this gets your printer going again.
Jan 02, 2009 | Epson Stylus C70 InkJet Printer
Waste ink pad counter reset software.
Dear Sir,
My Epson R30 Photo Printer has a problem from Waste Inkpad Full massage and it's not working. I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have R390 model so, please help me to find right software to reset my printer. Thank you.
mallajanak@yahoo.com
Jun 14, 2008 | Office Equipment & Supplies
Replace or clean ink pad and reset chip
The waste ink pads in the bottom of the printer have "timed out", and the nagging message is automatically posted. To bypass the message, power the printer down, and hold down the STOP and B&W buttons on startup.
While this will (probably) remove the message, those messy little pads need to be replaced, or it'll get ugly under there. You'll probably pay about $65-$86 for an hour of tech help to clean it up. Check on line for procedures for unbolting the base and swapping out the pads; you might save yourself a little money and learn something useful about the machine!
Epson Stylus RX650 All-In-One Printer Logo
681 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
