Question about Toshiba Satellite A135-S2276 Notebook
A135s2276 screen is black.
Unit powers on. cd drive will open, but nothing on screen. I tried external monitor,but no luck. I noticed to left of the key board there is a button that looks like the world and across from it a box with a symbol in it, just above the play and pause button. This seems to be able to turn on the power.
  • 408 Answers
Chances are the video card is bad if the display is black and the external monitor isn't showing anything as well.
Posted on Oct 10, 2009
How can I fix Toughbook
If you screen was dimming on your Toughbook, then try to
attach an external VGA monitor when the Toughbook is
turned off, then power on the external monitor,
then power-on the external screen.
If the external screen works, then you may have a bad
inverter if you TB is 2007 or before.
If the TB is 2008 or 2009 or later, then probably your screen
is NOT LCD with an inverter but instead LED. Which means
that you have to replace the entire LED screen.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Apr 16, 2014 | Panasonic Toughbook Tablets & eReaders
My nec p9120 has power to it and the wi-fi is on but the fan and everything else is not running and my lcd screen stays black
Try connecting to an external monitor and see if that works. Is the hard drive activity light flashing at all?
Mar 20, 2012 | NEC Computers & Internet
Hi ive got a HP Pavilion dv6000 laptop with a black screen ,i have tried a external monitor and i have checked the ram but still black screen ,the lights are on and the fan is running..please help
Just try to power cycle the unit by removing all power sources (battery, ac adapter) and pressing the power button for at least 15 seconds. If this will not work and you did not get an image from the external monitor, then you need your motherboard replaced.
Good luck.
May 19, 2011 | Computers & Internet
Hp g61 notebook pc bios blink error code 2 black screen led lights above num lock key and led lights to left of caps lock key flash 2 blinks.no monitor when hooked up to an external monitor.cd disc drive...
If screen and external monitor do not work then the issue lies with the video section of your laptop. The video chip is soldered onto mo bo and there is noway you can replace it if bad. Kiss your laptop sayonara, salvage the hard rive and memory and get yourself a new laptop that works. And avoid HP - their customer service is non existent after warranty runs out. They refer you to a forum or tell you to get another unit - an HP of course!
Sep 08, 2017 | Computers & Internet
HP G61 NOTEBOOK PC BIOS BLINK ERROR CODE 2 BLACK SCREEN LED LIGHTS ABOVE NUM LOCK KEY AND LED LIGHTS TO LEFT OF CAPS LOCK KEY FLASH 2 BLINKS.NO MONITOR WHEN HOOKED UP TO AN EXTERNAL MONITOR.CD DISC DRIVE...
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
Mar 24, 2011 | Computers & Internet
I have a Lenovo T61 laptop. Upon powering on the laptop, I noticed that the screen had become a bit "pink" in color, on the lower left side of the screen. A few days later, the screen started...
Welcome to Fixya
Plug in the external monitor to the laptop and turn on the system. Wait for 3 mins and Press Fn and F2 to switch the screen to your external monitor.
Thank you for using Fixya!
Jan 22, 2011 | Lenovo ThinkPad T61 Notebook
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Blank screen (Black) on Acer Aspire 9100, 2005 version, Laptop
Because you have tried it on an external monitor tells me it's nothing to do with screen, inverter or backlight.
This because if it was any of the above you would still get a display on the external monitor.
It's either one of two things: faulty memory or its not seated properly. check on the system memory, clean the contacts and slots and make sure you seat it properly. if you have more than one stick of memory installed take one out and rotate them one at a time turning the laptop on in between.
If you still get nothing on screen then chances are that the GPU (graphics processing unit) is shot.
Good luck.
Dec 04, 2009 | Acer Computers & Internet
Mine similar except the blue light stays on ,monitor goes black
Have you tested the monitor? The monitor could be faulty. Try hooking up the computer to another monitor or another computer up to that monitor if possible. If the monitor is testing good then make sure all USB devices are disconnected and try to boot again. Then open the case and blow out any dust. Check the motherboard screws are tight. If the screws holding the motherboard to the case are loose it can cause a grounding issue. Then swap out the power supply with a working one and see if that fixes it. Disconnect hardware one at a time and re-boot. One of the devices...cd-rom,harddrive,ect could be faulty. Make sure the video card is fully seated and test the card in another working computer or test a working card in that computer. If it has on-board video then install a video card if available and see if it works. If none of these things work then the board is bad and needs replacement.
Sep 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
Jun 29, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
