Question about Honeywell Heating & Cooling
My AC quit blowing cold air all of a sudden while I was out of town - my wife turned off the compressor and turned the fan to on, thinking it may be froze up - 2 hours later still no cold air - service light is also on - Thermostat is a Honeywell t874r
    President:
  • 2,976 Answers
Depending on how it's wired, she might have turned it off and on again and popped a breaker. It could be wired with a breaker for the fan motor and a breaker for the compressor.
Posted on Oct 07, 2009
03 grand am ac wont blow cold air
Two things are very likely to be your problem. Freon or compressor. Turn on the ac on cold and see if the compressor is engaging, if it is and stops and goes or if it doesn't. try to check the compression on the low side of your ac, the smallest plug where you service the ac. Or take it to an ac professional to get it refilled or checked. Remember, just because its blowing air, it doesn't mean its working. There are fans inside the car that push the cold air inside your vehicle and most of the time these will work, but that's not the only part required to blow cold air inside your car, the compressor is what makes the air cold.
Oct 09, 2014 | Cars & Trucks
Carrier home AC #BRC036 quit blowing cold air thru vents
Possible indoor fan motor not working or if it's blowing air just not cold air then compressor not coming on on outdoor condenser
Jun 05, 2013 | Heating & Cooling
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
The AC stops blowing air for a while and then re-start working normaly.
Have you noticed that the AC quits blowing cold air when you are heavy on the throttle, or climbing a hill? Does it return to blowing cold air when you let back off the throttle and relieve the load from the engine?
If you answered YES to those questions, your AC is operating normally. AC compressors take quite a bit of power from the engine to operate. In vehicles with smaller engines, the AC compressor will disengage when there is a heavy demand for power placed on the engine, and you will not get cold air. When that demand is gone, it re-engages power to the AC compressor.
Dec 03, 2009 | 2006 Mazda 3
AIR CONDITIONER QUIT WORKING
Pop the hood, start the vehicle and turn the AC on. Watch the compressor, it should have a center that rotates on an off and you should hear a clicking sound. This is the compressor clutch you are looking at. If the compressor is not doing this, check the fuses for the AC. If the fuses are good, then most likely the high side sensor switch is not working, therefore the clutch never engages and the air never gets cold.
Try that and get back to me, ok?
Sep 18, 2009 | 2003 Kia Sedona
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
How to conect my air condittinion pinguino pca L90
This really Expensive AC quite on me. The fan works great, I hear the Compressor turn on and it still doesnt blow cold air. Should I flip out?
May 14, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Heating & Cooling Logo
184 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
