Question about Kenmore Dishwashers
Clean light flashes 7 times at a time.
Dishwasher won't start anymore.
  • 10,515 Answers
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
Testimonial: "Wow! Solved my problem in seconds!"
Clean light is flashing 7 times, stops and flashes again. Can't make it started anymore.
my whirlpool is doing the same thing. I'm trying to find a wiring diagram with not much luck. A work around I use is to turn the breaker on the fuse box off for 5 seconds then back on. The dishwasher then works for one cycle.
Aug 09, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
My dishwasher isn't working. The clean button
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
189 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
