Question about Samsung SGH-U600
Samsung U600 cannot receive from bluetooth without paring pin
  • Anonymous Jun 25, 2008
    pin bluetooth ?
  • 405 Answers
Pin is "0000"
Posted on Feb 19, 2009
I need paring instructions for my HS850 to my Iphone.Both from the HS850 and the Iphone side.
To pair the bluetooth headset with your iPhone. Switch on the headset. Then in the iPhone goto settings then bluetooth you can see the iPhone is searching for devices. If it sees your HS850, just click on it and when asked to enter a pin, give in 0000.
Once the iPhone knows your device, I should find it every time both are switched on. (Bluetooth must be switched on on the iPhone)
Jul 12, 2014 | Motorola Mobility HS850 Consumer Headset
Isound road talk transmitter paring pin code?
Just purchased, couldnt find documentation in the package, tryed toguess the code per usual standard device pin codes. 1234, 0000, to no avail... but I looked a little harder for the documentation in the package, subsequently found the instructions behind a false panel, and the code for pairing is 9999... there you go. Good luck everybody!
Aug 02, 2012 | DreamGear Radio Communications
How to pair jabra bt500v to a blackberry curve
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT500V.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank you
Sep 03, 2010 | Jabra BT500V Wireless Headset
What if i can't find my model phone for instruction to connect to?
Hi
3. Search for Bluetooth devices and select Jabra BT2070.
Thank You
Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 17, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Paring the Bluetooth
You have to enter the security code into your phone once the phone receives the connect to signal from the radio, the default code is 1111
Apr 26, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Bluetooth paring pin number
If you go to your local bmw dealership they can connect their tester and access the bluetooth code from you vehicle in about 2 minutes. steve
Jun 17, 2008 | 2007 BMW 328xi Sports Wagon
Blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Oct 18, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
Samsung SGH-U600 Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
