TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
To set the time and date (must be done in this order) 1. Press MODE 3 times, then press START to change the seconds. 2. Press RESET to change the minutes, then press START until you get to the right minute. 3. Press RESET to change the hour, then press START until you get to the right hour. Note: If it says "H" on the right circle, it should read 24HOURS, otherwise it should read "A" for AM and "P" for PM. 4. Press RESET to set the date, then press START until you get to the right date 5. Press RESET to set the month, then press START until you get to the right number. 6. Press RESET to change the day of the week, then press START untilyou get to the right day. 6. Press MODE when done. Hope this helps
Welcome to FixYa!
Here's your request.
TIME AND DATE
CHRONOGRAPH
Thank you for using FixYa!
Have a great day.
Jas247
Time and date setting are only necessary if automatic setting by radio broadcast is unsuccessful. To set time, date, and options: 1) With time and day showing, press and hold SET. 2) City code flashes. Press START/STOP to select city that represents your time zone. See table below for city codes. 3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF). 4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to scan values 5) Press MODE. Minutes flash. Press START/STOP to change minutes 6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero. 7) Press MODE. Year flashes. Press START/STOP to change year. 8) Press MODE. Month flashes. Press START/STOP to change month. 9) Press MODE. Day flashes. Press START/STOP to change day. 10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format. 11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is selected, watch chimes on every hour. 12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is selected, watch beeps for every button press. 13) Press SET, at any step, when done setting. Press and hold MODE to switch between 12- and 24-hour time format. Press SET to view date. Year is at top of display and date is below. Press RECEIVE to view current city. Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK SYNCHRONIZATION section.
Try this:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
The watch should start when the winder is returned home position.
If pressing the winder does not cause the watch to start it could be that the winder may need to be screwed in (some watches include this as an additional feature to improve water resistance). Turn the winder to the right.
The wacth should now start. if it still does not start, I suggest you find your nearest dealer in your area and speak to them about it.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME: 1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US) These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
