Question about HP Compaq Presario V2000 Notebook
How to use laptop with a USB cable to reboot another laptop
  • 557 Answers
If you install abtutor on both computers you can work on other computer only with network cable
Posted on Oct 07, 2009
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
How to put my usb hdd to lap top
Plug in USB cable, reboot if necessary.
Nov 26, 2012 | Dell Vostro 1510 Laptop
I got error on printer LBP2900 when connect to my laptop (windows 7) It show communication error but usb connection and software installation no problem. Any idea about it?
Most likely it is a corrupt software installation.
You can try the easy things first: 1) Unplug the USB cable from the computer 2) Reboot 3) Plug the USB cable back into the computer, see if the communication error happens again
If that doesn't work, time to reinstall the software: 1) Go to Control Panel > Add Remove Programs OR Programs (depending on which version of Windows you have) 2) Remove every piece of software related to your printer 3) Unplug the USB cable from your computer 4) Reboot 5) Disable any Anti-Virus or Firewall software that you have running 6) Re-run the printer installation software
Jul 04, 2011 | Computers & Internet
It did not start up i have to reboot it there no CD room ans Cable for Reboot so how can i reboot it?
You can use, USB Flash Drive as Boot Medium. It is required to make some changes in the BIOS. Chnage the Boot Prirority, select the First Boot Device to USB Device. This will resolve the Issue. It is required to copy all the files in the REcovery Medium to the Flash Drive and for installation.
Nov 24, 2010 | HP Mini 1000 Netbook
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
I cant store video files in my kingston 32gb pen drive pl tell about service center in india
Sir/Ma'am
Bigger isn't always Better..... most older laptops out there cannot READ/WRITE or even understand a USB drive bigger than 8Gb (some not even 4)
It may be that your 32Gigger is too big for the PC to handle and b/c this is all a function of the BIOS and USB Controller chipset in the laptop, it cannot easily be changed.
BUT... Look on the Tech sites to see if there is a BIOS update/patch or fix for your laptop to enable it talk to the big USB drives, and Download it if there is.
Then all you need to do is make a DOS boot disk, add that updater file you downloaded, add and edit an Autoexec.bat file to automatically RUN the updater, reboot your Laptop with AC/120/240volt cable plugged in, and boot from the floppy you just made.
Very important: Once the BIOS updater is launched and running, it MUST absolutely finish by itself. You CANNOT and MUST NOT stop it or let the battery die (why you need AC cable)
When it is done, it will tell you to power off and/or Reboot. This can take 1minute or many hours (sigh). When you reboot, the Laptop will read/write your massive 32Gb USB Memstick.
Get the DOS Boot disk here: http://www.bootdisk.com
Make a noise if you need any more help
Feb 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Reboot maah hp for hp dv6405us
Hi Ash,
1. Check the CD drive and remove any CD inside.
2. Remove any USB drive from the USB port.
Your laptop could be configure to start up from CD, USB, or Floppy Drive before the hard disk.
Rgds
S88
Jan 02, 2009 | HP Pavilion DV6405US Laptop
The power / on-off button is flashing rapidly when I attempt to switch on my x1290, and it is not communicating with my laptop, despite USB cable being connected OK. The printer is unresponsive to pressing...
Panic over!! I unplugged the printer from the mains, took out the USB cable etc, rebooted my Laptop, and plugged the printer back in again... this time, when the power button was pressed, everything worked as normal, and it seems to be staying that way.
Jun 10, 2008 | Office Equipment & Supplies
Wont print says its ready
Remove the USB cable from laptop, reboot the laptop. Turn off the printer and turn it back on. Once you are in windows, plug the USB cable back in. Sometimes the machine will lose it's connection. By doing the above steps will renew the connection. ope that helps.
Feb 27, 2008 | Office Equipment & Supplies
Regarding Toshiba Satellite Laptop(CD Rom faulty so how to reboot XP)
try to check the bois if it is capable on booting in USB. you can load your copy of windows in the USB and boot it there...or try to look for another laptop that has the same CDROM connector.
Oct 24, 2007 | Toshiba Satellite A105 Notebook
HP Compaq Presario V2000 Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
