Air conditioner is freezing up - Heating & Cooling
    Problem Solver:
  • 5 Answers
1. check the indoor coil, if you have dirty evaporator COME FROZEN
2. low in freon
3. restriction in some dryer filter
4. blower motor fail
5. dirty air filter
6. bad blower run capacitor
THANK YOU
Posted on Nov 12, 2009
  • 80 Answers
Three most common things that cause an a/c to freeze up.
  1. Plugged/dirty filters
  2. Blower motor not running
  3. or there is a leak in you refrigerant system and you are now low on charge
Posted on Oct 07, 2009
Fix freeze up
There is a reason they freeze up 1. low on freon..2 evaporator coil needs cleaning(inside coil)..3. very dirty air filter, any one of these for a an air conditioner may freeze up... due to a number of other reasons. The most common reason for an air conditioner to freeze up is low on refrigerant.
Jun 27, 2015 | Heating & Cooling
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
Ac freezes at night
Many air conditioners are not made to run at less then 65 F outdoor air temps. The pressures drop too low and they freeze up...you could try to have someone check and make sure that it is not a bit low on charge... that would make it freeze up sooner...
heatman101
Sep 14, 2010 | Dometic Rooftop RV Air Conditioner
2 and half straight air unit freezing up after several hours system has o61 piston should it be something diffrent
No, the system is undercharged... add more freon to the system to raise the evaporator temp. so it does not freeze...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
heatman101
Sep 01, 2010 | Goodman Heating & Cooling
My air conditioner is freezing up what do i do
Check the air filter and have the charge checked... these are the two common reasons why they would freeze up...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
Why is my air conditioner freezing up?
The most common reason for an air conditioner to freeze is a clogged evaporator coil. Check and see if the filter is clean If yes then pull the unit our of its case and use the garden hose to clean it out. If it freezes after all of these steps it likely needs a shot of refrigerant.
Jun 27, 2010 | Haier ESA306 Air Conditioner
It keeps freezing up if you put it past #5
Hi and welcome to FixYa. I am Kelly. Freeze ups are caused by a couple things.
1. The first thing is a dirty evaporator coil. Air conditioners that run 24 hours a day should be thoroughly cleaned every 90 days.
2. The Blower fan wheel is dirty
3. The fan motor is not running fast enough.
Most of the time these 3 items listed above are the main reasons and Air Conditioner Freezes up.
Thanks for using FixYa,
Kelly
May 10, 2010 | Friedrich Casement SC06H10D Air...
Air keeps freezing up
you may have a ref. leak or possible the fan motor is not running as fast as it is supposed to.
Paolo
May 05, 2009 | Heating & Cooling
Freezing Up
sounds like air is not flowing properly thru the a/c. if there is a filter you can pull out remove it and clean it.
Robert
Sep 01, 2008 | Fedders A6X05F2D Air Conditioner
Goldstar R1804H
well u should take it out the window and dran the water out unite thwe water is gone then put it back ang if u still see that its freezing try it again and then put it one and u my have to do this offin to keep it from freezing
Jun 28, 2008 | Goldstar R5050 Air Conditioner
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
