Question about HP Compaq nc6230 Notebook
Would like to take Close/Take out wireless in CMOS?
    Brigadier General:
  • 4,044 Answers
Short Answer. You Can't remove that from the CMOS. You maybe able to disable the built in wireless from the CMOS but you will have to enter the CMOS configuration and follow the screen prompts to disable it. Unless you can re-write teh CMOS code you aren't going to take it out. To enter CMOS setup try pressing one of the following right after you start teh computer: F3, Del, Ins, Esc.
Posted on Oct 07, 2009
Where is the cmos jumper
The cmos jumper is on the mother board, usallyl close to the cmos battery. Normal settings are on or off (CLEAR) Be sure you know what the settings are suppose to be before reseting the cmos snf sldo how to reset them. you should turn the machine off and unplug the power supply. You can go to hp web site and look at the documention for your machine, Also be very careful not to unplug anything by accident.
Aug 05, 2014 | HP 8470p i5 3210M 14.0 500G 4GB -...
How do I reset my password
on board password with jumper clear cmos You have 3 pinns on motherboard near battery clr cmos jumper close 1and2 open jumper from 1and2 and close 2and3 after few sec put jumper back on pin 1and2 and your cmos is reseted and bios need set new settings for windows have utilities depends of software
Jul 18, 2014 | AccessData Password Recovery Tool Kit (ftk...
Locate the password (PSWD) and CMOS (RTC_RST) jumpers on the system board.
These jumpers are almost always located close to the CMOS battery or close the PSU power connector. If you open the unit up and remove the drives to see the board, it'll be either green or blue and it'll say PSWD right beside it. Remove it, power on wait for the Password Clear message....done.
Dec 27, 2013 | Dell Optiplex GX280 (99301) Motherboard
Where is the CMOS battery on the HP G60-235DX? How do I remove it? Also, what type (model #) of CMOS battery does this laptop have?
Shut down your laptop and disconnect all power sources. Turn the laptop over and lay it face down.
Remove the screws that secure the hard drive cover and remove the cover. Take out the remaining screws that secure the hard drive to remove it.
Locate the RAM (random access memory) and wireless card cover. This is often located in the center of the laptop. Remove the retaining screws and take off the cover.
Remove the RAM module by spreading the retaining latches on each side. Tilt the RAM module at an angle and slide it out of its compartment.
Disconnect the cables from the wireless card and remove the screws that secure the wireless card to the motherboard. Remove the wireless card from the laptop.
Locate the CMOS battery. It is about the size of a coin and is secured by a clip. Unclip the CMOS battery and remove it from its compartment. Insert the new one and reassemble the laptop.
Here's a link to a video that shows you how to do it too. http://www.ehow.com/video_4984398_change-laptop-battery.html Hope this helps! Don't forget to rate.
Dec 21, 2010 | HP G60-235DX Notebook
How to reset bios password on e machines e627
I just got done resetting the password on the emachines e627. I ended up dissassembling the unit, desoldering the cmos battery from the motherboard, soldering it back on, and reassembling. It booted to windows after this. Repair time: 2 hours. It is a little difficult since I didn't have the repair manuals. The emachine connectors for the keyboard, touchpad, and wireless are fragile at best. After doing it once, I could do it again in 30 minutes.
Apr 14, 2010 | Computers & Internet
Switching on wireless.
Normally there'll have a button or slide on top or side of laptop to turn on wireless. Or there's a wireless manager program sits on the tray and you can use to turn on the wireless as well (install one from manufacturer if it's not there). Finally, check the CMOS to see if wireless is enabled there. You can get to the CMOS by tapping DEL, F3 or F2 (depend on models and usually display momentarily on screen).
Oct 31, 2009 | Internet Compaq Evo N600C Laptop
Location of CMOS Battery
The C-mos is green about a half inch wide and three inches long with two wires leading to a connector, and is generally located under the memory cover on the bottom of the machine. However, with this machine, it may be located under the bottom plastic cover in order to make room for the wireless card. It will be very close to the wireless card and memory.
Jul 04, 2008 | Dell Latitude C640 Notebook
IBM ThinkPad R50e
So wait, its asking for a BIOS/CMOS password? If so, one thing you can try to do is remove the CMOS battery. The battery is about the size of a nickel and can be found on the bottom of your laptop. You'll have to unscrew a few things to find it. Once you do, take extreme precaution when touching anything inside the computer. I would recommend getting an Anti-Static Wrist strap (sold at Best Buy). Once you locate the CMOS battery, take it out. Keep it out for about a minute and then put it back in and close everything back up. When you do this it usually resets the BIOS/CMOS password if there is one. Hope this helps!
Jun 24, 2008 | IBM ThinkPad R50e Notebook
HP Compaq nc6230 Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
