Question about Philips 42MF230A/37 42 in. Plasma HDTV
Damaged Ribbon Cable on my Plasma TV, is it replaceable?
Stupid me, I have damaged one of the ribbon cables from the display panel to one of the buffer boards on my TV. My tv now displays a black square where that buffer is. The end of the ribbon cable that plugs into the buffer board is where the damaged traces are. I trimmed off the damaged end with scissors thinking this would fix the problem and the cable would still make contact in the connector. It does fit in the connector and it seems to make good contact, however the TV still shows a black square where that buffer is. My only hope is if I can replace this cable, the part number on the cable is C59K0033. My only other thought is perhaps the connector on the buffer board is damaged or it shorted out due to the damaged cable. Someone please help
  • soulflyseanb
    soulflyseanb Dec 31, 2012
    I have this same problem, but the symptom is a horizontal bar with weak pixelation. When I wiggle the appropriate ribbon cable, I can get it to work a bit better, but not perfectly. Is there a way to get the connection restored completely?
4 Suggested Answers
  • 52 Answers
SOURCE: TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Posted on Aug 19, 2008
tonyw514
  • 66 Answers
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
Posted on May 24, 2009
jdvillanueva
  • 2098 Answers
SOURCE: I have Time Warner Cable,
No, your unit is not HDMI compatible but you can use the HDMI connection possible using the DVI-HDMI adapters. Hook up the DVI male adapter to your TV (DVI port) and then the HDMI male adapter to your Cable box.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jul 04, 2011
Tip
LCD Side Screen Display Not Displaying
I managed to strip the digicam and found the MAIN FEED RIBBON CABLE DAMAGED du to normal open & close and turning of the sidescreen.
Replaced ribbon cable. PROBLEM SOLVED.
Hope this may help.
Aslam
on Feb 13, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
Where can I get some ribbon clips for a vizio tv?
Socket retainers/clips are almost impossible to fins as replacement parts. You may try the following:
Oct 02, 2012 | Vizio XVT473SV 47 in. LCD HDTV
How di i fix an ic on plasma ribbon cable
It is not likely to be fixable and if possible see if a replacement is available
May 29, 2012 | Televison & Video
I took this laptop apart to try and fix the sound jack and speakers, in the process of doing this I think I damaged a couple of pins on the flat ribbon cable with 12 pins that goes from the power button to...
the smoke means that you have a short circuit somewhere on your laptop double check the connections that you have made you might have to replace the flat ribbon make sure there is no dust at these connections you have to keep a computer free of dust/causes static electricity otherwise it can cause it to overheat and many other problems
hope this helps
May 12, 2011 | Acer Computers & Internet
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
My Sony Plasma Display
It sounds like you have a bad connection from either the X sustain or Y sustain boards to the panel itself. After the set warms up, the connection completes and the line goes away. First remember there are DANGEROUS HIGH VOLTAGES IN THE SET AND YOU CAN BE SERIOUSLY HARMED OR KILLED IF YOU TOUCH THE WRONG THING SO BE CAREFUL!. I would get a non conductive probe of plastic or wood and, with the set on and the back off, push on the ribbon cables which connect from the sustain boards to the panel. Once you determine which ribbon cable is the problem, disconnect the power, wait AT LEAST 30 MINUTES FOR THE VOLTAGES TO DRAIN OFF and then carefully resolder the ribbon cable connections at the sustain board in question. If the problem is at the panel end of the cable, I wouldn't recommend you try soldering there as it is very easy to damage the panel connections. You may try simply repositioning the ribbon cable to see if you can find a spot with a better connection. Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Sony PFM-42V1A/S High Altitude 42 in....
Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
May 29, 2008 | Toshiba 50HP66 50 in. Plasma Television
Balck lines
Yes, this is an LG/Zenith unit. You have one of two things going on here. 1) the X-driver board for that segment has failed (this is the board that the ribbon cable plugs into) or 2) the COF has failed on the ribbon itself. If you remove the two screws holding the metal plate that is attached to that ribbon, you will see components embedded in the ribbon. The ic may be visibly damaged or may have failed internally. Also, there are surface mount resistors on there too. Sometimes these open up, or are loose. Check for proper value and/or touch-up with soldering iron.
When neither of these solutions work, then the complete pdp display assembly will need to be replaced. Chances are the warranty company will replace the unit for the customer due to cost and/or part availability...Jeff :-) Recommend a trained person to check these
Jan 05, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Open Questions:
Philips 42MF230A/37 42 in. Plasma HDTV Logo
711 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
