Panasonic SA-HT930 "INIT" Message
Hi:
I'm having problems with the display. An "INIT" message is diplayed in the main unit screen, I have followed the steps from the troubleshoot instruction in the owner's manual and have not succeeded. Any advice?
Thank you for your help.
Sincerely,
B. Brown
  • 5 more comments
  • rjavinal25 Mar 20, 2008
    i have the same problem after the extended warranty expired. I have the same model and same error message "INIT" it happened after i inserted a disk. The disc was not jammed when I open the unit.
  • Anonymous Apr 26, 2008
    i'm having the same problem and can't figure out what's wrong with the pos... it started doing it for no apparent reason
  • Anonymous Jul 21, 2008
    When I turn my Panasonic HT 930 system on, it says INIT and nothing happens. I have looked in the trouble shooting section of the manual but there is nothing on that problem. Plugging the power cord doesn't work. Tried a number of random things and it still won't work.
  • hclarkncharl Aug 20, 2008
    Has there been any resolution regarding the INIT situation? The directions in the user manual simply do not work, and are not geared toward INIT on the receiver and not the Tv.... It seems like a simple code issue... and I dont want to drag it in for service....
  • Anonymous Sep 15, 2008
    I have exactly same problem, just started doing it after normal use, it's been cut off for a day then when i turned it back on it started displaying INIT and won't do anything
  • schooey Nov 18, 2008
    i had same after power spike
  • mlittman Apr 13, 2009
    Mine appeared when I played a slightly scratched disk.  Repair center says I should just replace it, but I'm not convinced that anything is actually broken---it could easily be a software problem!
Has anybody found a solution to this problem yet? I am also having this problem. Thanks.
Posted on Jun 21, 2010
Same problem. It appears to be a memory issue, the INIT error often arrives when many buttons are hit on the remote controller at one time, similar to a computers memory running slowly when either overloaded or the chip dying. My guess, and its just my guess, is that since i am not hitting multiple button which would confuse the unit, a memory chip in the unit is burning out and this is signal #1 to get it replaced before it takes everything else out with it.
Posted on Nov 10, 2008
I have that problem after an electrical short out.. wow, nobody knows how to solve it?
I hope somebody can fix this problem
Posted on May 31, 2008
I forgot childlock password in panasonic tv c400
http://eng.faq.panasonic.com/app/answers/detail/a_id/10865/~/how-do-i-reset-the-pin-code-for-parental-control-use-if-i-have-forgotten-it%3F
Online chat for support.
Instructions show above:
How do I reset the PIN code for parental control use if I have forgotten it? Please follow the steps below:-
  • Power the unit on.
  • Open the unit's drawer.
  • Select the BD drive with the Drive Select button.
  • Press and hold the REC and PLAY buttons on the front of the unit together for 5 seconds until the display shows INIT.
  • Confirm that the front display shows 'INIT'.
  • The parental PIN code has now been reset to the default code of '0000'.
Jul 25, 2018 | Panasonic Televison & Video
Tip
Try hard reset to clear most software lockups.
step 1: unplug cord step 2: plug unit in. Press and hold asterisk (*) key while dots scroll across display step 3: release (*) key when "all memory init" message appears step 4: unplug again step 5: plug unit in. Use L/R arrows to select country. Enter. Select language. Enter. step 6: Use Menu to set # of rings; volume.  Record message; Select TAM/FAX
on Aug 22, 2008 | HP 1020 Plain Paper Thermal transfer Fax
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
My panasonic sa ht930 volume when you give me presents on the screen and I f6 1 off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 18, 2011 | Panasonic sa-ht930 Home Theater Audio...
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Brother mfc465-cn unable to init 49
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
Jun 12, 2009 | Brother MFC-465CN InkJet Printer
1,458 people viewed this question
 Grubhead
Grubhead
