Question about Samsung Digimax S630 Digital Camera
Will a tokina 2.0 x converter lens fit a samsung S630
3 Suggested Answers
Gwenivie
  • 39 Answers
SOURCE: S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Posted on Jan 11, 2008
SOURCE: Lens
I had this problem with my daughter's D860, so the fix may help for this also.
As you know, externally the lens has two parts; the long barrel with glass lens at the front and the bottom part that rotates to move the long barrel in and out.
All I did was keep twisting the bottom part (that rotates) clockwise and anti-clockwise whilst turning the camera off and on. It may take quite a few attempts, but in my case it finally worked. So far anyway! who can say if it'll happen again.
Warning! Obviously take care how much pressure you put into twisting the rotating part of the lens. You wouldn't want to break it!!
Posted on Mar 08, 2009
Need adapter tokina 100-400 f/4.5 minolta to Canon Digital SLR
You need a Minolta to Canon adopter. Because the Tokina was made for the Minolta in the first place. Be aware that even with the adopter, there is a very great chance you always have to focus manually, because the lens can be fitted on the camera, but the electronics will not be compatible.
That is one of the things you almost aways lose, when using lenses from a different make.
Apr 06, 2014 | Tokina 100-400mm f/4.5-6.7 for Nikon
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
Can I use TOKINA lens 28mm-210 lens with this Nikon body or can I use with other NIKON body D 700?
Tokina makes their lenses with a variety of mounts. A lens with Canon mount, for example, won't fit onto a Nikon. Assuming you get the lens with a Nikon mount, then yes, you can use it with a D70 and with a D700.
Apr 16, 2011 | Nikon D70 Body Only Digital Camera
I have the tokina atx 280 pro lens but no hood, where can i get a replacement hood? or other brands that can fit in my lens. thanks
Most good camera shops and even some online camera stores should be able to help you
Part# BH775
also look here and contact this site as as long as it fits the lens size you have a variety of shapes.
http://www.jsteven.net/tokina-lens-hood/
you can make your own see this page
http://www.lenshoods.net/hoods/Digital-Lenshood-Tokina-AT-X-280-Pro-AF-28-80mm-f-2.8.php
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Tokina AF 28-80mm f/2.8 AT-X Aspheric Pro...
Where can i find cheapest Tokina lens AT-X116?
At Cameta Camera for $649,
B&H has it for less at $599 but it's out of stock.
http://www.cameta.com/Tokina-11-16mm-f-2-8-AT-X116-Pro-DX-Digital-Zoom-Lens-Nikon-AF-38451.cfm?utm_source=googlebase&utm_medium=base
http://www.bhphotovideo.com/c/product/554035-REG/Tokina_ATX116PRODXC_11_16mm_f_2_8_AT_X_116.html
Dec 30, 2009 | Cameras
I have a Tokina lens which says SD 35-200mm 1:4-5.6. The serial # is 8508870. What can you tell me about it, like what camera brand it fits?
Hello. The SD stands for Super Low Dispersion glass. It's a type of glass which is supposed to correct a lot of common light-transmission errors that naturally occur with optics used in this manner. All companies use "special" or "proprietary" methods of producing their respective high-quality lenses. The 35-200 tells you the focal length(how much zoom capability) you have. In other words, 35mm is considered a mild wide-angle lens while 200mm is approximately equal to a 10x pair of binoculars. Tokina makes lenses for a wide variety of cameras. There should also be a letter designation stamped on the rear of the lens mount. "O" for Olympus, "M" for Minolta, "N" for Nikon, "P" for Pentax, etc. Sometimes, there are 2 letters showing that the lens will fit cameras from 2 different companies.---Rick
Oct 02, 2009 | Canon EF-S 17-55 f/2.8 IS USM Lens
I have a tokina 500mm f8 lens with a P/K mount
This will depend on the lens you have now.
Some Tokina lenses have a universal fitting, with a separate adaptor mount for each camera body they fit. Its usually the last 5 - 10mm of the mount, and its identifiable by a second release button, which allows the specific fitting to be changed. If you have one of those, you just need the Nikon fitting.
If the P/K mount is an integral part of the lens, you have a couple of choices.
(1) You could get an engineering shop to alter the mount. This costs a lot and probably isn't worth the hassle. (It might be better to sell your lens and buy the nikon equivalent).
(2) You could use an adaptor. These are readily available on eBay.
For example:
http://cgi.ebay.co.uk/Pentax-PK-K-Lens-to-Nikon-AI-AF-F-camera-mount-Adapter_W0QQitemZ150400359906QQcmdZViewItemQQptZUK_Photography_CameraLenses_Lens_caps_hoods_adaptors_ET?hash=item23048f5de2
Note that just because it has the right (i.e. Nikon) fitting, it doesn't mean that it will necessarily have full functionality on the body you intend to use with it.
Some Nikon bodies are "extremely fussy" about which lenses they can use, and it might be worth evaluating whether your proposed solution would work with the camera body you have in mind before committing to any sort of expenditure.
Feb 15, 2009 | Tokina Cameras
Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro (www.bibblelabs.com) does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
May 20, 2008 | Tokina 12-24mm f/4 Pro DX for Nikon
What does my zoom lens fit?
The lens fits in vivitar, pentax,cosina cameras
Mar 10, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Samsung Digimax S630 Digital Camera Logo
20 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
