Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I have horizontal lines on my Mitsubishi 62525 dlp tv. it does this on cable and component sources (only ones i have hooked up). When you pull up the tv menu these lines do not appear and also the lines do not appear on a source thats not hooked up (turn to that source and get blue screen but no lines). What could be causing this issue?
  • 687 Answers
There are four HDMI connector types. Type A and Type B are defined in the HDMI 1.0 specification, Type C is defined in the HDMI 1.3 specification, and Type D is defined in the HDMI 1.4 specification.
The type of HDMI cable that you are using can effect the signal if your TV uses v1.4 and you have an older version cable say v1.3 then you will get lines
I am pretty sure that the HDMI cables are like USB which are backward compatible USB v1.1 devices will work with a v2.0 type cable. So if you have a v1.3 TV then you can use a v1.4 cable and so on.
Hope this helps please rate
Posted on Oct 26, 2009
  • 60 Answers
Bad capacitors. On my set HDMI looks clear, but component inputs have moving horizontal lines. There's a guy named Tbully on AVS forum that did a PowerPoint presentation that will point you to the capacitors to change. Sorry I don't have a link at this time.
Posted on Oct 12, 2009
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
KEEPS SHUTTING OFF
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-62525%2062
http://www.discounttvlamps.com/mitsubishi-tv-lamps-s/20.htm
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Only 1/2 of my mitsubishi 62 inch dlp tv screen illuminates.
Sounds like one of the light sources has failed or half of the projection source has failed(first is more likely)
If your TV is still on warranty you may want to call them to come pick it up. I doubt you'd want to move this yourself since it weighs over 100lbs
Aug 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 62in tv
You can get the owners manual on-line at mitsubishi-tv.com.
That should give you all that is needed.
Good Luck,
-Bill
Nov 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Jul 28, 2008 | Televison & Video
WD-62525 horizontal lines in picture when using component inputs
code 12 means the set isnt experiencing any shutdown symptons. I would check for more capacitors in the same circuit where you found the other often they show no visible sign of deterioration. If you need a service manual to figure out which capacitors are in that same circuit you can get the manbual for your set for 10.99 at the following link. They will even email it to you if you go back to the site and let them know you want it emailed. heres the link hope it helps.
http://servicemanuals.vstore.ca/
Jan 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,321 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
