Lands Phones Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 3 handsets an 2 r coming up with unregistered how do i get them back on
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Oct 07, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
36918
Points
198
Set them on the base station to register the handsets again!! hope this helps richie!
Magicbox vige twin says unregistered
I HAVE MAGICBOX VIGE BUT I WANT TO KNOW IF THE BACKLIGHT CAN BE SWITCHED OFF.
THANK YOU
JANE
1helpful
Unregistered Telstra V580a handsets
same problem here T.T really urgent
The handsets are displaying 'UNREGISTERED' and not working!
UNREGISTERED means the phone has not yet been set up to work with any particular base. I don't have any Phillips phones, so I can't tell you the procedure, but it should be outlined in the owners manual. Look for registering your handsets.
Registering a new phone
how do i register my new samsung rant phone ?
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
8helpful
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
16helpful
2answers
Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
1helpful
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
1helpful
2answers
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
2answers
How to REregister handsets
You can unregister your phone without being in the cradle, but to re-register them, just put them back in the cradle.  After being unregistered, they will automatically re-register once they are put back in the cradle of the main base.  Try setting them back in the base cradle to re-register, and hopefully that will work for you.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
