Question about NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter
Connection drops and no available network
Connection drops after 5-40 minutes. Try to scan and my WN111 can't find any available network. I need to unplug my adapter, restart windows and plug it in again. Installed new drivers but it didn't help. I have Vista and WN111 v1.
  • o_galushko Oct 07, 2009
    I have a laptop and it works with no issues. The problem with my adapter, because when I scan for available network, I have like 10 around my house, it can't find anything.
  • 2,263 Answers
So you are using windows Vista and the wireless connection is dropping.
Do you have any other wireless computer which is working properly ?
If the other wireless is working properly then the problem is with the wireless adapter. Now you have already upgraded the drivers, then there is nothing much we can do.
If you do not have any other wireless laptop working wirelessly, then try to bring another wireless laptop in the network and check whether it works properly.
If you face the same problem on that computer also that means the router might be having problem
Click Here for more info about the networking
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
WN11 did not come with the installation CD
Initial Installation:
  • Download the drivers for the wireless adapter from the support page using the link given below. Here, you will find several software versions for the adapter. We recommend you downloading the latest version available for best performance.
    WN111 Product Support page
  • Double-click and run the file you just and the follow the onscreen instructions to install the NETGEAR WN111 software.
    [Note: Click on Run when Security Warning window appears.]
  • On the Welcome screen of the Setup Wizard, Click Next to continue.
Oct 07, 2011 | NetGear RangeMax Next Wireless-N USB...
Keeps dropping connection
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 07, 2011 | Cisco (WS-X3011) Router
WN111 adapter only detects G networks, no N networks detected!!
your problem is simple and applies to most cases. It is lack of technological expertise or lasiness. By that I mean, You did not read the router manual or did not understand it. By default that router comes up in dual band mode. Meaning that it uses 2.4 Ghz for the G and 5 GHz for the N networks. If you want to benefit fully from the WN111 performance in the N mode then you must change the router to operate in a single band mode. (see the manual for the router to see how to do that). (hint: you need to bring up a broswer and type the router's IP address. netgear login standard is: admin and password is password. Go through the router setup and read the extensive explanations for each setup.
Dec 17, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
How would you know weather your wireless adapter is working properly are not.
on the taskbar, you will see a notification when the device is connected or disconnected. (wirelless connection not available).
Aug 01, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Wep key will not store...
Hi, This is a prominent issue with SP1 on XP.Either upgrade it to SP2 or above or use NETGEAR Utility to connect to the network instead of windows one.
To download SP2 visit microsoft website and for NETGEAR UTILIY follow the steps below:
1. Double click on WN111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.x.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 21, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
How can i connect Netgear WN11v2 to Nintendo Wi-Fi Connection Setup?
You can not connect this wireless adapter to your Nintendo. This adapter can only work with a windows based computer. If you have a wireless router and your Nintendo support wireless connectivity then you can connect the nintendo to the wireless network of the router.
Regards
Anand
Jul 17, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
When starting internet explorer ''no connection'' problem
can you restart the netgear? also see if you can connect ok with a cable. After all these, reboot your PC and check
Jul 08, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Netgear wn111 installation problem. " MICROSOFT WINDOWS XP UPDATE REQUIRED" before this application can proceed, you must update the Microsoft windows xp software on this computer. XP HOT FIX KB822603 The...
You are very limited here, but it's not impossible. Have you tried getting to a wired connection temporarily? A long way around would be to reinstall Win XP with a disc that includes the update. A word of warning though, the fix you have described (KB822603) is already included in SP2 on Win XP...SO... while you are connected to the wired internet connection, you may have to get an update for the driver of the netgear wireless wn111 hardware as well.
I hope this helps.
Jan 10, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter Logo
448 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
