Question about Vizio L32 32 in. LCD HDTV
32" Vizio LCD - noticed an arched shadow on screen
About a month ago, noticed an arched "shadow" extending from upper right corner of the screen to lower right center of screen - looks like a dirty swipe - shadow is only visible on lighter backgrounds - on close inspection, shadow appears to be behind outer screen - TV has never been bumped, etc. - outer screen is clean - TV is out of warranty (2 years old) - otherwise, TV performs perfectly - this is not a pixel problem - is this a heat issue, settings, or what?
pgh_pa_guy
  • 2992 Answers
SOURCE: toshiba 19inch lcd tv green line down screen
A solid line down or across the screen is due to problems in the display itself. Unfortunately, there's no way to repair it because the bad circuitry is integrated into the display. The only cure is display replacement.
Not the solution you want, but that's how it is. (With the huge number of transistors that are part of the display, it's actually amazing there are as few failures as there are.)
Posted on Jan 22, 2009
SOURCE: Vizio LCD Green Pixels
Our Vizio started doing the same thing after only three weeks, except it was also showing green pixel when we watched DVDs.  After checking this site and others and trying all the "tweaking" advised, I finally called Vizio's customer support.  They were extremely polite and tried to help over the phone, but had to send someone to the house to make the repair (anything 40 inches or larger earns a house call). The tech arrived on time and was extremely professional and pleasant -- he had to replace the daughter board and LVDS cables.  So far, so good.
Posted on Jun 29, 2009
  • 8 Answers
SOURCE: No picture on vizio lcd
It's likely not a backlight, but a mainboard. If you are feeling frisky, take the back off and get the model number off the mainboard and check eBay.
Posted on Aug 22, 2009
  • 12 Answers
SOURCE: No Picture on Vizio 42 in. Plasma
There is no backlight on plasma TVs. If you have a black screen than most likely one of your sustain boards are gone. Board can be purchased on line at about $100. If your TV has no signs of life it's most likely the power board. Any way it would not be that expensive to fix if you are able to take the TV apart and swap the boards. But I need to say that I recommend to do it ONLY if you are qualified enough. Otherwise ask your local TV repair company to service your TV.
Posted on Sep 06, 2009
  • 3 Answers
SOURCE: Problem with the picture on my Vizio flat panel
a better solution is to replace the LVDS cables or just reseat them as the contractor stated it could be a motherboard but about 90% of the time it is actually the LVDS cables ohm load that puts toomuch load on the motherboard. the cheapest solution if out of warranty is buy an lvds cable and simply replace it if the issue still exist after the cable is replaced it will be a motherboard issue but any time you have red green or blue speckles on a vizio TV you should always swap the cable first since quite simply put it is the most common point of failure with that issue.
Posted on Feb 01, 2010
Shadow on right side of screen
Can you please give little details of shadow on right side?
Is it Vizio L32 lcd tv or any other model?
These info will help me to diagnose problem.
Thanks.
Nov 28, 2010 | Vizio L32 32 in. LCD HDTV
My 32 in vizio was knocked off its stand and cracked the screen in upper right corner. can the screen be replaced?
Hello, the screen assembly can be replaced, but at a cost that would make it not practical, my suggestion would be to either look for a used lcd screen or sell the TV as is and buy another one.
Oct 02, 2010 | Vizio L32 32 in. LCD HDTV
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Vizio L37 Television
Tell me how to regiatrar online
Follow this link. Click on register in the upper right han corner. Input your information
http://www.vizio.com/
I hope this solution is helpful. Please take a moment to rate this solution.
Feb 11, 2009 | Vizio L32 32 in. LCD HDTV
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Vizio L32 32 in. LCD HDTV Logo
218 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
