Question about Video Game Consoles & Games
There is something wrong with my ps2 77003 the disc spinning lens moves till now its fine but there is neither sound nor video onley a black screen?ant its not a cable related probelm...so what the hell is going on?plz help
  • 64 Answers
Sounds like an internal problem most likely with the wires connected to the video cord slot on the back of the PS2. you'd have to have someone open it up and make sure everything is connected properly
Posted on Oct 24, 2009
My dvd player won't spin. The TV is fine. Could a dvd lens cleaner work if a disc doesn't spin?
The lens cleaner will not work if the disc wont move. It sounds like the drive motor is blown. Could possibly be a fuse, but if your not experienced troubleshooting electronics I do not suggest you fix it yourself. Honestly it would be cheaper to buy a new dvd player than having this one fixed.
Mar 05, 2011 | Audiovox Televison & Video
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
My cd player on the Sony HCD-G101 rotates the discs but ...
i had the same problem after i moved and everything ran but when i put in a cd the disc would spin for awhile then change to the next disc and just kept spinning and moving from one disc to the other none stop. so i opened mine up turns out during the move there is a small black plastic piece that sits on top of the laser in the middle it shifted during the move making it block the view of the disc. you will have to carefully remove the plastic piece from the top of the laser with out touching the laser lens and that fixed mine good as new. my problem is i need the remote code movers lost my remote and can't find the code to use the replacement i bought. Hope it helps if this is the same problem i had should work. i tried to move the black piece back into place but it just did not go back right to just removed it all together. they did not use anything to really hold it into place to avoid slipping.
Dec 15, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Sony PS2 station wont play
moisten a microfiber cloth with isopropranol alcohol and clean the lens and black rubber ring on the top surface of drive motor
and also clean the surface the disc you are tring to play then retry dvd.
you can clean lens with canned air also
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
Playstation 2
IF THE DISC IS NOT BEING READ THEN THERE IS SOMETHING WRONG WITH THE LENS INSIDE THE PS2. IF IT IS BEING REA THEN TRY OPENING THE PS2 TAKE OF THE TOP. LOCATE THE TRAY COVER AND THERE IS A WHITE OBJECT IN THE MIDDLE, TRY SPINING IT. IF IT DOSEN'T MOVE THEN PLAY WITH IT UNTIL ITS LOOSE. ThEN TRY PLUGIN BACK THE PS2 AND INSERTING A GAME (DO NOT PUT THE TOP BACK ON) INSERT THE GAME AND SEE IF THE WHITE OBJECT IS TURNING WHEN THE DISC IS READING..
IF IT IS THEN THE DISC IS SPIINNING,
HOPE IT WORKS FOR U.
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony2 slimline model scph-70002
Hi gollywog,
The laser not moving sounds like the connection from the motor that moves the laser to the motherboard has become dsiconected. You can usually get movement of the laser, and the only reason is something is wrong with the motor or its connection to the motherboard.
Nov 08, 2007 | Sony PlayStation 2 Slimline Console
PS2 Makes Sounds and Keeps Pausing Games
Hi Ebridges2,
The Game your playing is probably a Blue colored media.  That is ones that spin so fast.  You console has become dusty and loaded with lint probably.  You can open the case and clean up the insides. Also while your in there, remove the ocver and polish up the lasers lens.  This will probably get you back in business. If you do nto have success, contact me at Repairtech@ playstationclinic.com   I run The Playstation Clinic at www.playstationclinic.com  If you have a Slim Model it will cost more than the big model to repair.  The slim model is $41 full refurbish including return shipping inside the USA.  The big Fat PS2 Versions are $36 including return shipping.
Oct 14, 2007 | Sony PlayStation 2 (PS2) Console
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Video Game Consoles & Games Logo
110 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
