Question about Refrigerators
Sub Zero model 590 Part Number
I am looking for the part number of the sub zero 590 dual water inlet valve. Help!
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: sub-zero model 590 - replace
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 21, 2011
Why is Water leaking out of the bottom outside corner of my sub zero fridge
I would guess your drain is clogged and leaking. Without a model number I can't instruct you where to look and correct this issue. Good Luck
Aug 12, 2014 | Sub-Zero Refrigerators
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
Sub zero ice maker waterline frozen
What is the model number of your unit?
Nov 01, 2012 | Refrigerators
The ice maker won't stop dripping.
The problem is going to be the water inlet valve isnt fully closing and seeping water through it all the time. To fix it the water inlet valve would need to be replaced,typically on all Sub-Zero brand refrig's the valve will be up by the compressor in the area above the ref. behind the top grill.
Also while up there replacing the water inlet valve be sure to clean all the dust from the condenser coil as well as replacing the water valve.
GENE
Sep 06, 2011 | Sub-Zero Refrigerators
I have a sub zero 690/F refridgerator and need to get a new ice maker motor, water valve and fridge gasket can you help me?
Dear yilsu,
Parts can be ordered through our Regional Factory Certified Parts Distributors. They will need your model and serial number in order to properly assist you. You will find their contact information by following the link to our Locator. Select 'Service, Repair and Parts', enter your zip/postal code and you will receive a listing for the Factory Certified Parts Distributor for your area.
http://www.subzero.com/locator/locator.aspx
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Jan 16, 2011 | Sub-Zero 690 Side by Side Refrigerator
How can i find stainless steel panels for the front of my sub zero model 590
We are factory authorized Sub Zero parts and service. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST for all your Sub Zero parts and supplies.
We look forward to hearing from you. Thanks, Ella
Nov 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice maker will not stop!
You are going to have to replace the dispensor module. Go to http://www.subzero.com/locator/locator.aspx?type=0&zip= for your local parts distributor or service agent. The factory number is 800-222-7820 and they are very helpful.
Dec 18, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
