Question about Kenmore Oasis HE 27082 Top Load Washer
On the display window it always reads F1 when you start it up.
  • 80 Answers
The F1 error code indicates that the signal from the water level pressure switch on the machine control board is out of the normal range. This can be caused by the pressure hose between the bottom of the tub and the pressure switch being pinched, twisted or kinked. If this pressure hose is okay, then the machine control board will need to be replaced to correct this problem.
Posted on Oct 07, 2009
After booting always to F1
The F1 key is often a notice that something is not right in the part of the computer that runs before the operating system (i.e. Windows). What is wrong is usually displayed in the rest of the message. It might be that your "floppy" drive is not working (you may not even have one), or that the "date and time" are not set, or that the chip that sets up your system before Windows starts has been reset to incorrect settings for your configuration.
On most systems there is a key you need to push, usually the DEL key, as the system first starts. (It may also be the F10, F2 or F1) Push that key several times...about 1 time a second...as you start the system. This should take you to the BIOS screen (BIOS being the name of the chip that runs everything before Windows takes over). In there you can look at the date and time...if they are not current, or close to current, your BIOS chip has a problem. If they are current, if you restart and carefully read the message that came up with the F1 key you will know where to look in the BIOS to fix the setting.
If the date and time are not correct you need to have the CMOS battery replaced. This is not the main laptop battery, but the little watch battery used to keep the date and time (and other settings needed) when you have shut the system off and/or disconnected the larger laptop battery.
If it's this problem...the time and date wrong...you will probably want to take it into a shop and have them change the battery. The little CMOS battery is only a few dollars (under $10) and the labor should be reasonable if that's all that is needed.
Dec 17, 2014 | Microsoft Windows 7 Ultimate. Windows 7...
Tip
Windows Shortcut Keys
<ol> <li>Windows: Display the Start menu</li> <li>Windows + D: Minimize or restore all windows</li> <li>Windows + E: Display Windows Explorer</li> <li>Windows + F: Display Search for files</li> <li>Windows + Ctrl + F: Display Search for computer</li> <li>Windows + F1: Display Help and Support Center</li> <li>Windows + R: Display Run dialog box</li> <li>Windows + break: Display System Properties dialog box</li> <li>Windows + shift + M: Undo minimize all windows</li> <li>Windows + L: Lock the workstation</li> <li>Windows + U: Open Utility Manager</li> <li>Windows + Q: Quick switching of users (Powertoys only)</li> <li>Windows + Q: Hold Windows Key, then tap Q to scroll thru the different users on your PC</li></ol>
on Dec 27, 2010 | Computers & Internet
Tip
Don't Ignore the Windows Logo Key
The Windows logo key, located in the bottom row of most computer keyboards is a little-used treasure. Don't ignore it. It is the shortcut anchor for the following commands: Windows: Display the Start menu Windows + D: Minimize or restore all windows Windows + E: Display Windows Explorer Windows + F: Display Search for files Windows + Ctrl + F: Display Search for computer Windows + F1: Display Help and Support Center Windows + R: Display Run dialog box Windows + break: Display System Properties dialog box Windows + shift + M: Undo minimize all windows Windows + L: Lock the workstation Windows + U: Open Utility Manager
on Dec 15, 2009 | Computers & Internet
I need instructions on how to use the hot keys and function buttons
F1
  • Almost always used as the help key, almost every program will open the help screen when this key is pressed.
  • Windows Key + F1 would open the Microsoft Windows help and support center.
  • Open the Task Pane.
F2
  • In Windows commonly used to rename a highlighted icon or file.
  • Alt + Ctrl + F2 opens a new document in Microsoft Word.
  • Ctrl + F2 displays the print preview window in Microsoft Word.
F3
  • Often opens a search feature for many programs including Microsoft Windows.
  • Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
F4
  • Open find window.
  • Repeat the last action performed (Word 2000+)
  • Alt + F4 will close the program currently active in Microsoft Windows.
  • Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
F5
  • In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
  • Open the find, replace, and go to window in Microsoft Word.
  • Starts a slideshow in PowerPoint.
Jan 15, 2011 | Computers & Internet
Advise uses of all F Keys.?.
F1
Open the Task Pane.
F2
F3
F4
Open find window.
F5
Sep 30, 2010 | Logitech EX110 Mouse
When i turn my HP Desk top monitor displayed fan pin not connected,Then bottom of screen has F1 for booting,then we press F1 windows has start up. THX
can I buy some puctuation?
i can not understand most of that.sorry....
D330 PC, check
unstated monitor, what monitor of 1000s/?
post all that works and not, only all facts solve problems
we are blind here, cant see you or it. (those parts)
"displayed fan pin" i read that 10 times and draw a blank...
i see your screen is not dead ,it prompts you with text
I bet the BIOS hot key work , do they ,sure.
OK yes, the F1 joy, this is when BIOS discovers that the COIN cell is dead, as all PCs are this old,
dead dead dead, its just $2 coin cell battery
see this
https://support.hp.com/us-en/product/hp-compaq-d330-desktop-pc/342066/manuals
see
service man
http://h10032.www1.hp.com/ctg/Manual/c00059138
see page 46
BINGO, coin cell *****.
wow it lasted 11 years, , that be like a world record
Id frame the sucker.
Oct 13, 2017 | HP Compaq Business Desktop d330 Slim Tower
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Windows xp always starts with keyboard
Go the control panel> device manager and uninstall the keyboard but keep the drivers. When the system reboots it will recognize the hardware and reload the drivers. If asked, let windows search online for an updated driver. When it is finished installing the hardware, reboot to check the results.
Sep 15, 2009 | Computers & Internet
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
My display window reads e1 and f1 and we can't get anything to work
tholt, for the model posted F1 E1 is a eeprom error in the board. Try pressing and holding cancel/off key for 5 seconds. If that doesn't work unplug or disconnect the power for 1 minute. Plug it back in, if the error comes back it probably is a bad control board. Most common cause of control failures is caused by corrosion on the connectors. I would seat and reseat all the connectors to the board, including the keypad ribbon. Give this a shot and post back, Catriver.
Apr 20, 2007 | Whirlpool SF380LEPS Gas Kitchen Range
Kenmore Oasis HE 27082 Top Load Washer Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
