Question about U-Line Echelon 2075RF Compact Refrigerator
Freezer is very cold, refrigerator is warm. Fans are operating. Mouse chewed through some wires. I reconnected them but am wondering if I did something wrong.
  • 286 Answers
Your evaporator fan motor is what helps cool the refrigerator side. The fan may not be going fast enough, Is there frost on the back wall? Check the fan direction. You should be able to feel the fan **** from the top and it blows out the bottom of the evaporator. If it does and no frost My suggestion is to replace the fan
Posted on Oct 08, 2009
Right side won't cool, but it appears all four fans are working.
Is the freezer ok? If not you may have a refrigerant leak. OR chemical smell is burned insulation on a control wire. or possibly the light or light switch. If control wiring there may be control vanes or similar to valve that are not allowing cold air from the freezer to refrigerator part to enter.
Mar 26, 2015 | Refrigerators
Refrigerator is warm and will not cool food and the freezer is iced up
Theres the problem an iced up freezer, the cold for the food compartment comes via a fan in the freezer, no flow, no cold, firstly defrost it completely, check fans are working, if they are ok then it's probably your defrost hester element.
Nov 22, 2013 | Refrigerators
Evaporater coil was frozen. Thawed out. Fan is running. Refrigerator was warm. Restarted, refrigerator warm. Freezer to cold frosting. Dampner to refrigerator not staying open.
My first guess is defrost timer, is stuck in defrost, if you can find it, turn it, and if the compressor and fans turn on, you got your answer.
Jun 30, 2011 | GE GBS22HCR Bottom Freezer Refrigerator
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
Hello I have a frigidare refrigerator Model #GLRS64ZEB7 that doesn't get cold. I cleaned the condensing coiled. I tried it and it still didn't work??? The compressor is running the suction line is getting...
Unit is low on freon......
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 14, 2010 | Frigidaire FFHS2311L Side by Side...
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
After cleaning coils my refrigerator is still blowing warm air yet the freezer is cold what can I do myself to make the refrigerator cold?
There is a small fan which moves the cold air from the freezer to the refrigerator part. Make sure that this fan is working. If it is not turning, the cold air will not reach the refrigerator.
These fans are easily replaceable; however, you probably will have to remove the interior panels from the refrigerator to gain access.
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
My refrigerator/freezer is not get cold
If the compressor and the fans are not working then the ref is stuck in defrost. Check the defrost timer
Aug 11, 2009 | Maytag MTB1953HE Top Freezer Refrigerator
GSH25JSRFSS: Replaced main control board but still does not work
Remove the indide back cover in the freezer. If the cooling fins are iced up, give it a full defrost, Look for any holes to the outside near the pipes. Plug them. Chances are a mouse climbed up and chewed the styrofoam and you're sucking warm room air in and the moisture is freezing (icing) up the coils. Ice in the airflow channel can cause clicking against the fan.
Mar 19, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Hotpoint rfa70 fridge seems not to be staying cold
just give it time as the freezer has to come down to temp first
Jun 05, 2008 | Freezers
Refrigerators Logo
62 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
