It's most likely the Y-Sus, or Y Sustain board to be more accurate. It's located on the left side of your picture under the support rail and connected to the upper and lower Y-drive modules.
Pull it, send it to PTS and then re-install. Testing isn't an option unless you have a scope and schematics and if you had those I doubt seriously you would be needing the help.
Note: it is a rather difficult job just to pull that board and re-install it... Be VERY careful not to damage the ribbon cables connecting the Y-Sus to the Y-Drive boards.
Bill
SOURCE: Philips FlatTV Black Screen 30PF9946D/37
I have the same problem and was told by my local TV repair shop I needed a new LCD panel (at $2000!!!) which I don't believe for a moment since the panels themselves rarely fail. After digging around on the net, I came across a posting from "Arfa Daily" on the sci.tech-archive.com website which points to either the backlight inverter board or the power supply. So far, it is the only intelligent thing I've found that makes any sense. If anyone follows this up and sucessfuly repairs your set, please let me know! ....Acepayday
I will re-post his/her answer here but to read it yourself goto:
http://sci.tech-archive.net/Archive/sci.electronics.repair/2008-05/msg00508.html
"Max" <maxg70@xxxxxxxxxxxx> wrote in message
news:hb6dnebEeZuhqrfVnZ2dnUVZ_sDinZ2d@xxxxxxxxxxxxxxxxxx
sstepanov@xxxxxxxxx wrote:
Hello! I have a Philips 30PF9946D/37 30" LCD that no longer turns on.
Upon pressing the power button, the status LED goes from green to
amber then to red.
Is this a common problem with these?
Thank you!
Could be ps board.
It's a common problem with all LCD TV sets. First, try unplugging the
display panel's backlight inverter board. It is very common for these to
fail and cause the set to revert to standby. Otherwise, it's most likely
that the PSU itself is faulty - also very common.
Examine it *very* carefully for bulged electrolytics on the secondary side.
Note that these may be 'hiding' under bits of heatsink, so look carefully.
Also, check all large and heatsink-mounted devices, for bad (lead-free !!)
joints, which is another common cause of your described symptoms. Other than
this, you're a bit 'on your own' with LCD sets. There are other possible
causes, such as bad sound output chips, but if you really do have a power
supply problem that's not one of the things described, then you will
struggle to get to the bottom of it without schematics, and an intimate
knowledge of switchmode power supplies. These LCD ones are infested with
monitoring circuitry for output voltages and over-current conditions, and
they all work on the standby supply, so if *any* unexpected condition is
detected either at startup, or during use, the standby supply is momentarily
stopped, which causes the system control micro to reset back to its 'sleep'
condition, removing the 'power on' signal to the power supply. Depending on
the set, that may then be an end to it until you try to bring it out of
standby again, or it may just keep trying on its own, causing a flashing
power light.
If you can prove which board is causing the trouble, you might want to
consider just replacing that board. PSUs and inverters for many sets, can be
found astonishlingly cheap on the 'net and e-bay sometimes.
Arfa
SOURCE: My Philips 19pfl3403d/f7 wont turn on without unplugging first.
main power supply going out..needs to be changed..easy job..
SOURCE: power supply is bad on philips plasma 50 inch tv, it just clicks
nice job... thats the most common problem with all LCD tv's now
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
