Question about HP Officejet 5610 All-In-One InkJet Printer
Hp offficejet 5610 printer showing paper jam
I have checked everything, I cleaned it, I cleaned the rollers, I uninstalled and reinstalled both the drivers and programs, yet the printer keeps telling me there's a paper jam, but there is NO PAPER JAM!!
    Guru:
  • 81 Answers
Try This :
>Open the rear access door clean the rollers inside it with the help of a Lint free cloth moistened with some distilled water.
>Check inside the printer if there is any paper jammed inside.
>Unplug the power cable from the back of the computer
> Keep on tapping the power button of the printer
> Plug in back the power button.
> Try to do a photocopy and see if it works .
> Again unplug the power cable from the back of the printer . Press and hold down the (#) & (9) and then plug in back the power cable . Then release the (#) & (9) button.
> It will perform a reset . If still it doesn't work check the link given below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=ca&lc=en&dlc=en&product=441125
Still if it doesn't works can contact HP for repair or Replacement
Hp No.: 1-800-474-6836
Regards
Shrey
Posted on Oct 07, 2009
I had paperjams and i pulled out the paper from the front of the printer. I have done this more than once. I then found out recently that it was best to remove the back and pull ot the paper. Could...
I always recommend that paper jams be removed in the direction the paper would normally travel. Forcibly removing jams generally will not damage rollers, as the hardware tend to cause paper to tear before anything breaks. Removing paper jams in the wrong direction however can break one-way "finger" paper path sensors occasionally. If you are not experiencing a jam every single print, you are probably in good shape.
As for cleaning the rollers, if you have taken the rear door off the printer you are halfway there. You should be able to turn the rollers in one direction or the other by hand. There are plenty of products out there to clean rubber rollers (I use Blow-Off Rubber rejuvenator) but rubbing alcohol on a cloth can work as well. Turn the rollers to get at the entirety of them and scrub along the length with an alcohol dampened rag.
Jun 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer has paper but it wont catch and when it trys it says paper jam.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf2
Aug 21, 2009 | HP Officejet 5610 All-In-One InkJet...
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp officejet 5610 all in one keeps saying paper jam and there is no paper jam
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab47
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam error with no paper ...
Put your hand in and poke at the front and poke all the levers and move things around a bit it sounds like a stuck switch and poking them normaly frees them up.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
The printer says Paper Jam even there is no paper in it
Please try to clean paper jam area with referring to instruction manual. You printer needs cleaning...
May 04, 2009 | HP Office Equipment & Supplies
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam
Fiend your solution direct from hp. Here is your solution...
334
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
