Question about Texas Instruments TI-89 Calculator
My calculator hangs up 20 second before i turn it on. If i get off its batteries, the calculator run other 20 seconds and then hangs up. Then i downloaded the latest OS (3.20) and it runs until i turn it off, when i turn it on again it has the same 20 seconds problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Try a hard reset and see if that clears it up. Be aware that this will clear all RAM.
Press and hold the 2ND, left-arrow, and right-arrow keys.
Press and release the ON key.
Posted on Jan 17, 2010
How to turn OFF Casio QL-10?
The photo you have given is fx-300 ES. In that you have to press SHIFT and than AC so that It will turn off.
May 31, 2013 | Casio fx-300ES Calculator
My TI 83 Plus won't turn on, I adjusted the brightness, held DEL while reinserting batteries, replaced batteries but nothing changed
hi bckyshldn,
Did you remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. In the procedure that I give, you hold [DEL] and, re-insert 1 battery. I'm going to go ahead and, restate my instructions for a ti 83 Plus that won't turn on.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me anybody could make the same mistake. and of course the calculator will never come on if the batteries aren't in correctly.
The process below should reset your calculator.
Please be prepared to re-install the calculator's OS if you run through this process.
Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  1. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
    reinsert the AAA battery and then turn the calculator on. The calculator should display the
    message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator did not display the message try pressing and releasing the [2nd] key followed by pressing and releasing the up arrow for one second. goto step 2.
  2. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
    "Waiting...Please install calculator software now". Follow the instructions for the
    TI-83 family or TI-84 Plus family to reinstall the calculator operating system. If the calculator did not turn on connect the calculator to the computer and open Ti Connect. Next, open Device Explorer. Is the calculator asking to be installed? goto step 3.
  3. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Now just in case this calculator wasn't posted correctly. Here's my instructions for a Ti 83 that won't turn on. This is not the same procedure that the Ti 83 Plus has.
  1. Try a new set of AAA batteries.
  2. Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds. Now, Pressing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. Is the screen showing any activity? If not continue the process.
  3. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the
  4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. And of course if the calculator does not turn on, I re-do the procedure and, increase the amount of time by 5 minutes to ten minutes that all the batteries are removed.
Jan 04, 2011 | Texas Instruments TI-83 Plus Calculator
How can I find sin 45degrees 20 minutes using a fx-9750G PLUS calculator?
The problem is not finding the sine of the angle but expressing the angle in Degree Minutes Seconds instead of decimal degrees.
  1. In RUN screen press [SIN] function key
  2. Press [OPTN]
  3. Press [F6] to get to next page of menus.
  4. Press [F5:Angl]
  5. Enter 45 and press [F4: degree ' "]
  6. Enter 20 and press [F4: degree ' "]
  7. If you have seconds to enter, type in value and press [F4:degree ' "]
  8. Press [EXE] to get your result.
This procedure will give you the sine regardless of the angle unit the calculator is configured for.
Sep 30, 2010 | Casio FX-9750GPlus Calculator
I let my batteries run out over the summer and now that I've replaced all 4 AAA batteries and the backup CR1620 battery I still have an expensive calculator that won't turn on. I've tried to press the...
First, make sure there's no corrosion on the battery contacts and that the batteries are inserted the proper way.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 23, 2010 | Texas Instruments TI-83 Plus Calculator
This is the second calculator I've broken. The first read low battery, then I didn't use it for a few weeks. The next time it wouldn't turn on. First I replaced the AAA batteries. Still didn't work so I...
If this doesn't fix it, please reply to this post and we'll go on from there.
Sep 22, 2010 | Texas Instruments TI-83 Plus Calculator
Ok, so i replaced the batteries in the calculator.. And now it wont even turn on. Brand new batteries and everything, Any suggestions?
Hey this sounds like the classic contrast problem.
But first make sure that the batteries are good and that they are installed with the proper terminals alligned correctly
Second, and this is the classic problem, turn on the calculator and then press second and up. The screen should begin to darken and you should begin to see the cursor.
If you go to far or in the even that the screen is dark, lower the contrans by pressing second, 2nd, and then holding down.
Hope this helps
Happy Calculating
Aug 19, 2010 | Texas Instruments TI-83 Plus Calculator
I have an older 1995 TI-82 that suddenly will not turn on. I changed the batteries including the watch battery and still nothing. Is there a reset or do you have a suggestion?
The following are 4 different things you can try that is on the Texas Instruments Website: " 1. Try a new set of AAA batteries. 2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow. 3. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on. 4. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. "
Feb 12, 2010 | Texas Instruments TI-82 Calculator
Seconds into hour minute second
Use the witeView Mode or fraction mode
20000s /3600s/h gives 5 full hours, remain 2000 seconds,
2000s/60s/h gives 33 minutes remain 20 seconds.
Result is 5h 33 min 20 sec
Do not confuse the DMS degree, minute, seconds with th hour minute seconds.
Hope it helps.
Feb 13, 2009 | Sharp EL-531VB Calculator
Turn-on woes My TI83 will not turn on. Batteries new and installed correctly. What gives? Khumalo
Take out the AAA batteries and hold the on/off key for thirty seconds. Replace the batteries and it should come on. If it doesn't remove the backup battery and the AAA batteries and hold the on/off key for another 30 seconds. Replace all batteries and turn it on again.
Oct 13, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-89 Calculator Logo
70 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
