Question about Dishwashers
My GE dishwasher PDW7800G00BB leaks at the bottom / middle of the door. There is no gasket, what could it be?
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
please check the 'o' ring of the drain line inside the washer it will be worn out please change this ring and there should be a gasket to avoid the water leakage of the water from the door so please call the engineer he will help you to work on these.
Posted on Oct 07, 2009
Kitchenaid dishwasher door leaks out bottom middle of door when it goes into drain mode?
You probably need to check the door gasket for proper sealing and maybe replace it if the dishwasher has been in use for awhile
Oct 13, 2012 | KitchenAid KUDI24SE Built-in Dishwasher
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
I have water leaking under my dishwasher (probably right in the middle). I put a paper plate underneath to catch the water during the cycle. There seems to be some "soap scum" on the bottom where it is...
Hello there
Here is several ideas that will help you
also (fyi) type in search engine how things work and once it opens just enter dishwasher and it will bring you to the dishwasher section ok?
here it is
Dishwasher is leaking water
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Water or soap leaks around the door
  • Make certain that your detergent is intended for dishwashers. Do not use liquid dish soap.
  • Inspect the door seal gasket
  • Check the door latch
  • Inspect the door hinges
  • Inspect the spray arms for damage
Water drains through the air gap into the sink
Sep 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Jul 11, 2009 | GE Dishwashers
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Soap and water coming out the front of the dishwasher
I would think that the gasket is not doing the job, can you pull the gasket together to decrease the gap. If not then try another gasket if it's not on warrentee
Apr 18, 2009 | GE Nautilus 24" Built-in Dishwasher
When starting dish washer water comes out at bottom of door about in the middle
You don't list the manufacturer or model number, not its approximate age but there are generally two things that need to be repaired or adjusted when you have a leak.
1.) The door gasket
2.) The door latch ... but if after you close the door and it latches, if it appears to lock tight, replace the gasket.
Good Luck! Please post back here what you find and decide to do, OK?
Apr 17, 2009 | Dishwashers
Ldf8812st lg dishwasher leaking from front door
Thank you for the update. The retrofit kit will probably not only fix your leak but also dry your dishes much better.
I hope the info I provided was useful. Can you take a moment to rate my level of helpfulness?
Mar 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
220 people viewed this question
Top Dishwashers Experts
