Question about Boating
I just purchased a Miya Epoch Electric Reel Deepest 1100. From Japan. No Paperwork. How do I Fix it to the boat. I imagine you bolt the reel to the rod and somehow this is fixed to a swivel fixed to the boat How ?Ray Riles.
  • raypatriles Oct 07, 2009
    I just purchased a Miya Epoch Electric Reel Deepest 1100. I did not get any paperwork with reel From Japan. I have a small Electric Reel but when I got this one it is very large. I want to know how I fix it to the boat. I imagine you bolt the unit to the rod and somehow fix the unit to a swivel
    fixture on the boat, Can you buy such a fixture and if so where. Thank you.
  • 8,197 Answers
To get the manual you need to contact miya epoch at.
info@technotreninfo.com or reelgolf@cs.com
Good Luck
Posted on Oct 07, 2009
    President:
  • 1,734 Answers
You will get the answer here:
http://www.miyaepoch.com.au/
or here:
http://fishraider.com.au/Invision/index.php?showtopic=28893&pid=239990&mode=threaded&show=&st=&
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Where can I get a schematic on K Mart 207 level wind fishing reel?
Some quick research revealed that the original manufacturer of that reel was Olympic Reels based in Japan. Unfortunately I did not have any success in locating a schematic.
Contact Mike Willsey at this link Home after January 9th and he should be able to assist you.
Oct 13, 2014 | Fishing
Reel wont engage to wind in line
Depending on the reel it could come apart differently. On a closed face reel you normally turn the top half about 1/4in. and then the top pulls off. On a open faced reel if you look atop the cylinder that the line wraps around there should be a screw on there. Or sometimes the whole top of the cylinder unscrews.
Dec 08, 2012 | Boating
Reel is slipping when under strain on retreval making loud grating noise when this happens
It sounds like the gears are stripped. When the reel is under strain the body of the reel may flex and cause the gears to misalign and slip. These gears slipping and skipping may be the grinding sound you hear. Graphite body reels are more susceptable to body flex than metal body reels. Gears can also wear out due to lack of proper lubrication. Some manufacturers supply replacement parts for their higher end reels and the reel can be rebuilt with new gears. You will need to check with the manufacturer to see if it could be rebuilt. If it is an inexpensive reel then it will be much more cost effective to just replace the whole reel.
May 16, 2011 | Boating
MANUAL FOR COMMAND AT-3S MIYA EPOCH
buy manual from technotronics
Aug 23, 2010 | Epoch (E9I162GB)
When ever I reel in my line the reel doesn't reel it in very smooth and clicks alot
remove the spool and check the teeth and gear arent missing a tooth-if not give it a good clean and oil
Sep 23, 2009 | Shimano BTR6500B Live Bait Reel--CP12B 7'...
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Jan 28, 2009 | 1992 Honda Accord
Boating Logo
117 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
