Question about Dell Latitude D600 Notebook
My dell D600 laptop turns off by itself. when i turn on the caps lock light blinks four times and the laptop turns off.....please help
  • 61 Answers
Just reseat (remove & put back) the RAM (memory).
you can find the procedure for removing the memory in the support.dell.com. Follow the steps given below.
1.GO TO support.dell.com,
2. Click on "Manuals"
3. Select your system, or put in your service tag.
4. You can either view or download the manual for your system.
Hope this info. was useful....
Posted on Oct 07, 2009
  • Balan J Oct 07, 2009
I have a Dell Latitude D830 Laptop. One day i found out i can not turn on the laptop. The power light is on, and so the HDD light indicator.. and the caps lock light is blinking. But the screen keep...
Have you tried it with an external monitor?
If this does not help. then you may have a motherboard problem. The Dell motherboard is easily replaced and you can get one on e-Bay
Jun 07, 2011 | Dell Computers & Internet
DELL INSPIRON 600M , WHEN TURNED ON ALL THREE LEDS LIGHT UP THEN THE CAPS ON BLINKS FOR 9 TIMES THEM THE COMPUTER TURNS OFF...PLEEEEASE HELP
When the LED blink for couple of times and goes off its hardware problem with the computer... It might be a motherboard or the RAM that is causing this problem... Please take the computer to a local tech or call dell at 18006249896 to get the issue fixed
Oct 09, 2010 | Dell Latitude D600 Notebook
Have a dell laptop but it doesnt start when i push the power key a little lock with the letter a inside blinks what does this mean then the computer shuts off by itself
That icon is the indicator for Caps Lock (aka Shift Lock). When in the operating system (Windows), you can turn the icon on (or should be able to) by pressing the CAPS Lock key, and turn it off by pressing the CAPS Lock key again.
Jun 29, 2010 | Dell Latitude D600 Notebook
Caps lock "a" keep flashing on dell d600 when trying to start. Then turns off
Here is the answer. Memory Problem:http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
Jun 16, 2010 | Dell Latitude D600 Notebook
My loptop D610 turn on ,caps lock blinks and ater 3 to4 secons it
I would try clearing the cmos battery. It's located under a small door under the laptop battery. Unhook the wire (laptop unplugged) and let it sit for 20 minutes. Hook it back up and try to power up. If that doesn't work www.pcrepairhelp.net has techs that work on laptops.
May 04, 2010 | Dell Latitude D600 Notebook
DELL LATITUDE D600 fails to boot up
Hello
Thank you for using
FixYa for your problem
Not sure if it's a sure fix or not, but it worked for me.
I have a Dell Latitude c640 and when powering up, the caps LED would blink roughly 10 times, things would spin up, but after the 10 or so blinks, it would power down without anything having been displayed. This happened just after I had the laptop going on batteries, and it went into hibernate mode automatically after the batteries got low. When I plugged back up to a power supply and turned on, the computer started to exhibit this problem.
All I did was removed the bottom panel, removed both memory modules, put the memory modules back in the slot, rocked them at least 7 times before locking them back in to place to ensure a good seat, and completly seated them (clicks into place), closed up the panel, and powered up.
After doing this, the system booted up normally.
Just as a bynote , Faulty RAM, damaged motherboard affecting the RAM (ie cracked RAM slot where it was maybe forced in with a bit too much pressure) and lastly cooking the chip although this is a lot more rare.
Easiest way to check is get another laptop and swap YOUR RAM INTO IT if it affects that laptop then RAM, riskier is to switch ITS RAM into yours, still does it - generally MoBo.
there are also other problems that cause these errors, but in my experience these are the most common
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 21, 2009 | Dell Latitude D600 Notebook
The battery light blinks 4 times orange and 1time green when i plug the charger in, but will not turn on when plugged in either, it powers on but screen remains black, the cap lock and scroll lock blink...
yes if the battery is not shorted if it is it's another story. try removing the battery and see if the ac adapter will power it. if so then its the battery if not you have other troubles.
Aug 03, 2009 | Dell Latitude D600 Notebook
Dell Inspiron E1505 Will Not Turn on
Hi there.
Try cleaning the system memory and slots with a soft dry clean painbrush and re-seating it.
Also make sure the air vents and fan area is free of dust.
Good luck and thanks for using FixYa!!
Mar 23, 2009 | Dell Latitude D600 Notebook
My D600 internal microphone goes out all the time-Help!!!
Check you BIOS settings. How old is your laptop and what version of Flash Player is on your computer?
Apr 28, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
