What do the controls on a portabel AC mean. Like the mode button.
    Problem Solver:
  • 10 Answers
The mode button determines wether the unit is in "Auto" or "On": * "Auto" means that the fan turns on only when the unit has determined that the room/area needs to be cooled (fan on only when the compressor is functioning); * "On" means that the fan is always running, regardless of wether the unit's compressor has switched on to lower the room temperature.
Common reasons for setting the mode to "On": * you desire constant air circulation; * someone is sleeping and would prefer to have the unit running at all times (if it turns on/off frequently, it could disturb sleep)
Common reasons for setting the mode to "Auto": * uses little/no electricity while waiting for room temperature to rise; * if fan is always running, there is a risk of ice buildup
Posted on Oct 07, 2009
    Problem Solver:
  • 5 Answers
My 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Dash AC vents not blowing air
COULD BE BLOWER MOTOR OR RESISTER
Sep 07, 2016 | Ford Cars & Trucks
Toshiba Satellite L300D
I assume you mean it's in sleep mode and you can't get it out? Or you wish to put it into sleep mode, or perhaps you want to take a nap yourself? One word problems are very hard to solve.
If it's in sleep mode, take out the battery, unplug the AC, hold down the power button for 1 minute. Put the battery back in, attach the AC adapter, and press the power button. That should fix it. Putting it into sleep mode is generally done by pressing the power button for a second. And napping is generally done by putting your head down on your desk and closing your eyes.
Feb 16, 2014 | Computers & Internet
My 96 Sedan DeVille Climate control system will not toggle between Econ and Auto Modes. It will only operate in the Econ Mode. The Auto Mode lights up when I push the button but immiediately switches...
This usually means the ac refridgerant is low. In Econ mode the ac compressor will not turn on, your car is staying in Econ to avoid damage to the compressor. If you are low on refrigerant it means you have a leak. Don't just buy a can and refil, have a professional shop check for leaks and fill the system with the proper oil and add refrigerant to the proper pressure.
Mar 07, 2011 | Cadillac DeVille Cars & Trucks
Our Dometic RM2652 RV frig has 2 yellow lights on which are indicated to be alert lights. The frig/freezer seem to be working fine.......????? Is something about to go out on it?
The 2 yellow lites... if you would... Is there and indication by description of what those 2 lights are?
Here are the modes:
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp (A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system will automatically select between AC and GAS operation with AC having priority over GAS. If the control system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45 seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B) will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated after 3 or 4 tries.
If 120 volts AC becomes available while the CHECK indicator lamp is on, the control system will switch to 120 volt AC operation, The CHECK lamp will not turn off until the main power ON/OFF button is pressed to the OFF then ON position.
In AUTO mode operation, the temperature is controlled by a single temperature setting.
MANUAL MODE
When operating in the MANUAL mode, the AUTO mode indicator lamp (A) will be off, and the refrigerator will run continuously on the energy source selected by the control system.
NOTE: The food in the lower compartment may be frozen if the refrigerator is left on "MANUAL" mode.
STANDBY MODE . .
This control system contains a feature that will continue to operate the cooling system in the event of a failure of a major operating component. If the control cannot read the temperature sensor and operate at the preset temperature, then the control will run the cooling unit like the MANUAL mode.The refrigerator will continue to operate in this mode indefinitely or until a new sensor is installed and the
system is reset.
I posted the above information from the contents of the service manual. I can help you but... at the moment for sure I have come to the conclusion that ONE of the lights your seeing is the CHECK light. The mystery is... what is the 2nd light your seeing? Manual of Stand-by?
I am pretty sure we can sort this out but... we need to really communicate clearly and well. In our posts here.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Dometic RM2652 Refrigerator
Penguin model 610012-001a/c compressor won't start
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jeff
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Mitsubishi PAR-F27MEA AC controller icon meanings
hi.welcome to the mitsubishi worl of airconditioning.thay are great units to have.ok let me explane this for you.
the sun is for heat mode
the snow flake is for cooling mode
rain droplet is for dehumifiy the air if its a humid day.i hope this helps you.you have to choose the modes on the remote for the unit.then the unit will do the mode you choose on the day.
Jun 09, 2009 | Heating & Cooling
Loacked photo Files
CAN u EXPLAINE ME WHAT DO U MEAN BY LOCKED
LIKE WHAT HAPPENS
Dec 31, 2008 | SimpleTech Signature Mini 160GB External...
To format my nokia 2610 cell phone
salut dans mon portabel nokia 2610 ilya beaucoup de virus mais mon portabele n ouvrier pas comment je vais reguler
Aug 19, 2008 | Nokia 2610 Cellular Phone
Problem in 14" videocon colour tv
whats the videocon portabel flat tv internal service mode code
Aug 09, 2008 | Televison & Video
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
