Question about Casio Exilim EX-Z57 Digital Camera
The menu keys are sticking or scrolling on their own
1202 chinese font to english
1) Press the "Menu" key
2) Use the arrow key and scroll 3 times to the right
3) Press the "Select" key
4) Use the arrow key and scroll 5 times to the right
5) Press the "Select" key
6) Language is the first menu that will appear on the screen
7) Press the "Select" key
8) Scroll down to "English"
9) Press the "Select" key
Aug 28, 2014 | Nokia 1202 Cell Phone
How can I chg name on unit I just bought for Ken?
Hello.
1 Press the "Thumb Stick" to display the product main menu.2 Scroll down with the thumb stick and select"Options." Tap the thumb stick to enter the menu.3 Select "Owner Information," and tap thethumb stick to enter the folder.4 Enter or change the current owner data (Name,telephone, etc.). Scroll down with the thumb stick and select "OK."Thanks.
Sep 20, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
I try to scroll right on the MATH menu and it isn't scrolling through to give me options for decimal to fraction.
First, make sure you're pressing 2nd [MATH] F5 to get to the MATH MISC menu. To see additional items on the menu (in effect, to scroll through it) press the MORE key (just to the left of the left-arrow key), not the arrow keys.
May 22, 2011 | Texas Instruments TI-86 Calculator
Images from memory stick will show on frame but
Try these steps: 1. Insert the card.
2. Tap on MENU.
3. Select PICTURES and tap on OK.
4. Highlight SD/MMC and hit OK.
5. Once you see the thumbnails of the pictures, tap on MENU again.
6. Scroll down to MULTI-SELECT and hit OK.
7. Tap on MENU and scroll down to SELECT ALL and hit OK.
8. Tap on MENU and scroll down to COPY and hit OK.
9. Highlight INTERNAL MEMORY and hit on OK.
Dec 18, 2009 | Kodak 8" LCD Digital Photo Frame
How do i alter the sound when i send a text message
From the stand by screen press the "Menu" key.
Scroll to Settings and select by pressing the right soft key.
Scroll to Audio and select by pressing the right soft key.
The phone will display the current ringing profile or style.
Highlight the detail option and select Change by pressing the right soft key.
Highlight "Calls" and select Change by pressing the right soft key.
Scroll through all options and select the desired Ringtone or vibration setting.
Press the end call key to exit.
Deleting a Ringtone:
Press the Menu key.
Scroll to "My MEdia"press Select.
Scroll to "Sounds" press Select.
Highlight the Ringtone to be deleted.
Press the Menu key.
Scroll to and select Mark.
Press the Menu Key.
Scroll to Delete Marked Files press Select.
A pop up message appears "Delete from phone?"
Select Yes.
Nov 07, 2009 | Cell Phones
Is there a reset option on the samsung red rant i am umable to power on and i have a new battery
Try a Hard Reset:
Hard Reset will reset the phone to its factory settings and erase all data.
1. Press the MENU/OK key to select the MAIN MENU tile.
2. Scroll Up to Settings and press the MENU/OK key. 3. Scroll Up to More and press the MENU/OK key. 4. Scroll Up to Security and press the MENU/OK key. 5. Enter the lock code. For this example, press 7 to prompt one to fill in. If you can’t recall your lock code, try using the last four digits of your wireless phone number. If this doesn’t work, call Sprint Customer Service at 1-888-211-4727. 6. Scroll Up to Erase/Reset and press the MENU/OK key 7. Scroll to Reset Phone and press the MENU/OK key. 8. Read the Warning and press OK (Left Soft key). 9. Scroll Up to Yes and press the MENU/OK key. 10. Scroll Up to Yes and press the MENU/OK key to complete the reset. 11. For this example, once the reset is complete, scroll Down to No to decline to verify Wireless Backup
Oct 23, 2009 | Samsung Rant Cell Phone
How to verify sms/mms
  1. Press the Menu Key.
  2. Scroll to and select WebAccess.
  3. Scroll to and select Web Sessions.
  4. Scroll to "mMode", then press the Menu Key.
  5. Scroll to and select Edit.
  6. Validate the following:
    Note,Settings for multi media service will stop if the port 1 is blank
  • Name: mMode
  • Homepage: http://home
  • Service Type 1: WAP
  • Gateway IP:10.250.250.250
  • Port 1: 9201
  • Domain 1: Blank
  • Gateway IP 2: 000.000.000.000
  • Port 2: 8080
  • Domain2: blank
  • Service Type 2: WAP
  • DNS 1: 000.000.000.000
  • DNS 2: 000.000.000.000
  • Timeout: 5 minutes.
  • CSD no 1: Blank
  • Username: Blank
  • Password: Blank
  • Speed (Bps) 1: 9600
  • Linetype 1: ISDN
  • CSD 2: Blank
  • Username 2: Blank
  • Password 2: Blank
  • Speed (Bps): 9600
  • Line Type 2: ISDN
  • GPRS APN: Enter the your Apn
  • Username: Enter your user name
  • Password: Enter your password
  1. Click Done.
Once the browser settings are configured, please select it as the active web session:
  5. Select Set Default.
NOTE: APN: Access Point Name.
Please rate this a fixya
Feb 13, 2009 | Motorola Mobility RAZR V3
Motorola v3
  1. From the standby screen, press the Menu Key.
  2. Scroll to and select Messaging.
  3. Scroll to and select Message Inbox.Press the Menu key.
  4. Scroll to and select Cleanup Messages.
  5. Scroll to and select All.
  6. Press Yes.
Feb 15, 2008 | Motorola Mobility RAZR V3
Casio Exilim EX-Z57 Digital Camera Logo
12 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
