Question about Sony Handycam CCD-TR818 Camcorder
Door will not close on my Handy cam model TR 818 and it is flashing C:32:11
Yes, first of all thank you for you quick response and you should know that the service you provide is excellent, second to none.
I checked the online manual for the Tr818 and in the trouble shooting section they did have the code C:32:00 which stated to remove the power from the unit...So I disconected the charger and removed the battery for a few seconds. When I restablished the power to the unit the code was no longer there and it worked well after that.
sffas
Posted on Oct 07, 2009
ctf1800
  • 4402 Answers
SOURCE: Door Jam
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Feb 22, 2008
  • 149 Answers
SOURCE: ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Posted on Sep 10, 2009
welcomejee
  • 10594 Answers
SOURCE: my sony handycam dcr-hc26 door won't close
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Posted on Dec 09, 2009
SOURCE: my Sony DCR-HC62E error code 32:11 cassette door
search youtube for vids on this Sony camcorder C:32:11 problem .... there are several.
Posted on Oct 10, 2010
sonicboomele
  • 1557 Answers
SOURCE: Cassette door won't close. Error code 32:11
i have seen this fault 3 times sadly for me the first time i saw it. was 3 months after my wife spent $ 600 on a sony handy cam. as i dont like hard drive back up im still a tape man. as a tech that contracts to sony corp i called them and was told sorry we cant help the fault was found by sony very soon after building the slide top feeder on the very first hd series and they decided to keep making them anyway hoping hdd back up cameras would fade them out the repair is simple replace the intire take up cartridge the only problem i and my future 2 customers with the same fault found was it cost around $ 400 us. upset by this i contacted many electronics friends till i found one that told me to just hit it after laughing and telling him i know i should kick it he explained to me this is the only cost affective way to fix it and it worked what you do is bang the bottom of the camera very hard several times and in all 3 cases it worked. hold the tape holder shut and bang the bottom the cart will start to go down with my customers there cameras are still going mine did it again and i lost the plot and kicked it to the bin sadly thet dont make tape drives anymore so i spent $ 300 having the tapes put on dvd and now use a hard drive camera :(
best of luck please keep me posted as to how you go
merry christmas
sonic boom electronics australia
please take time to rank this advice below
thanks
Posted on Dec 24, 2010
How to transfer videos from Sony Handy Cam CCD TR 317 E
Check if you have a Firewire port that is either a 6pin or 4 pin port that looks like
Use a firewire IEEE 1394 cable kit and appropriate software too transfer to PC. Most firewire to usb cable will not work.
You will need a
1. Firewire cable
2. Firewire port on PC/Laptop as well.
3. Recent OS that supports firewire.
4. Appropriate image/video editing software.
Apr 22, 2014 | Sony Handycam Video Cameras
Fridge door not closing properly
This section of this refrigerator door repair guide will walk you though repairing a refrigerator door on a side-by-side refrigerator. On most side-by-side refrigerators there is a cam that lifts the door up when you open the door so that the door has a tendency to fall down and back into place while it is closing. If the refrigerator has a cam and it is working properly, the refrigerator door will rise up when you open it and lower when you close it. If this cam is broken the door will not close properly. A lot of refrigerators have two cams, one screwed on the door and one on the hinge. You may have to replace the entire hinge to replace the lower cam but the cam on the door can always be replaced. You will have to order the cam by model number and can do so on this website AppliancePartsPros.com.
On side-by-side refrigerators without cams there will be a spacer on the door hinge. If this spacer is missing replace it. Note that any plastic spacer will work as long as it will go on the hinge pin and is not too thick. Never use a metal spacer because this will cause wear on the door and it will eventually squeal when closing.
As on top-freezers the door gasket may be ripped and if so refer to the bottom section that talks about door gasket replacement.
Sometimes the door can get warped out of shape. If the door is closing at the top and not at the bottom or vice versa the door may be warped out of shape. You can fix this by twisting the door back into shape. Take you foot and place it at the bottom and pull the door out at the top or place your foot inside the door at the bottom and push at the top with your hand depending on which way you need to twist the door. Note don’t over do it twist it a little and if it isn’t enough twist it a little more. If it gets worse you may need to twist the other way.
hope this helpout ......
Aug 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hi , My Sony Handy cam Model number is :DCR-DVD105. When i try to shoot any thing after i switch on my handy cam i get the error " DISC COVER OPEN,ACCIDENTLY TRUN ON POWER AGAIN" Every time i switch off...
for this u hv to reach the service center of sony cuz this problem is related to hardware may be the cover is not getting closed properly or any inner switch is broken etccccccccccccc
proper solution is service center
Mar 14, 2010 | Sony Handycam DCR-DVD105 DVD Camcorder
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
The cassette door doesn't close HELP!!!
Try the following link:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 03, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Whirlpool refrigerator side x side doors make a popping noise if opened past halfway... model GS5SHAXNL00
The door closing cams were worn on both doors. I had to buy a cam kit that cost about $10.00 and had the parts for both doors in it, take off the doors, and replace the cams. Before taking off the door that has an ice and water dispenser, I had to turn off the water to the fridge, take off the front grill, and disconnect the water tube that goes into the door (as the tube is threaded through the door cam). After replacing the door closing cams and reassembling, there is no longer a popping sound.
Jun 10, 2009 | Refrigerators
Tape holder of camcorder isnt closing
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Jul 19, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony Handycam CCD-TR818 Camcorder Logo
100 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
