Question about Linksys Wireless-G WRT54G Router
Cannot connect new labtob computer to wireless network
  • 4,281 Answers
Turn the wi fi switch on your laptop.
first make sure that wireless network adapter driver installed and enable in computer.
Then right click on my network places click on proeprty then you can see your wi fi network adapter.
Right click on it then click on view available networks.
If you find your router nettwork then click on connect.If not found then you have to check in router configuration that wireless is enabled there.
For that connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you see configuration page of router.
Then click on wireless check it is enabled.
Also check That WEP is enabled or not.If enable then you need that wep key for connect network.It is in Wireless security menu.
Then save settings and restart router.
Then it find network.
Let me know if you need more assistance.
Thanks
Posted on Oct 07, 2009
Belkin f5d8235 unidentified network
Does it ask you for the wireless security password while connecting?
I think you can try creating a new wireless network on the router and see if that works.
What is the operating system on your computer?
How many wireless computers do you have?
Read information about wireless network connection on windows computer
Jun 14, 2012 | Belkin (F5D8235-4) Wireless Router
Can i connect new pc to old connection
You simply need to disconnect old computer from the network and connect the new one.
Are you trying to connect wired computer or wireless?
If you are trying to connect a wired computer then you don't need to do anything.
Just take out the Ethernet cable from the old computer and connect it to the new computer.
If you are connecting a wireless computer to the network then make sure that you have all the settings of your wireless router.
If your wireless network is secured then you should know the correct network key.
I will suggest you a website " The Router Setup " which may help you connect your new computer to the old wireless network.
May 17, 2012 | D-Link AirPlus DI-524 Wireless Router
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
My new laptop with Windows7 OS cannot connect either wireless or direct cable to DLInk DI624. I have tried turning off my firewall but still same problem persist. The router is working fine with my old pc...
Adding a wired computer or device to the network.
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Adding a wireless computer or device to the network.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
click Here for step by step instructions
Dec 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
MY LABTOB WILL NOT SET UP VIRGINS D LINK WIRELESS ROUTER EVEN THOUGH THE VIRGIN SETTINGS ARE CORRECT
May I recommend you give Network Magic a try. Free to download and evaluate, you will find it here: http://www.purenetworks.com/nmlp/home-networking.php?gclid=CPua-J-J1J4CFVw55QodUi_Nrw&src=google&kw=network+magic+download
NM is excedllent at resolving connectivity issues as well as assisting with security and device sharing. Many other features as well. You may agree with me, it is well worth the couple $ to get the 5 license paid version after the eval period, though they seill allow you to use a lesser version for free.
Thanks for posting at FixYa.com
please vote
thanks
Dec 09, 2009 | Computers & Internet
My computer was wireless until I changed modems becausethe old one stoppd working
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
May 01, 2009 | 2wire (1000-000057-000) Modem
I have labtob using win98 without lan port to conect to network use usb lan but not work with win98
Windows doesn't support plug and play until Windows Me. Upgrade to Windows XP. Be sure your computer has the minimum requirements for Windows XP before changing the opperating system.
Apr 17, 2009 | Network Computing Devices Computers &...
Thanks so much for been there!!
If youconnect to router via ethernet cable, then you should be able to access the router interface by typing in 192.168.1.1 in an address bar.
Jul 16, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
71 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
