Question about Frigidaire GLTF2940ES Front Load Washer
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
Your door isn't properly closed - adjust the load and close the door
Posted on Oct 13, 2009
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Posted on Oct 07, 2009
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES0 displays LOC when i press start
The control lock feature has been turned on. This prevents someone from accidently changing the cycle or starting one. To toggle off the lock, press and hold Options and Select until the lock indicator goes off. (Holding the buttons will toggle the lock back on.) If you look closely at the Control Panel, you will see a small padlock icon with a line between the two buttons that set the lock.
The manual for the GLTF2940ES0 is available here: http://www.frigidaire.com/manuals?model=GLTF2940ES0 . The direct link to the manual with information on the control lock is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134457800ef.pdf . See page 3.
I hope this helps.
Oct 02, 2011 | Frigidaire Washing Machines
Our Frigidaire GLTF2940ES0 washer was in spin cycle with 7 mins to go when is just stopped. No specific error code other then Err. It will not start at all now. Door locks and unlocks fine.
Sounds like the electronic locking mechanism is malfunctioning. It is secondary lock which is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 15, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer wont start it says LOC when i push the star button then err this is a front load frigidaire gallery
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Jun 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washing machine
Sounds like it needs replacing from what you have said. You could try to free up the locking mechanism by going behind the lock on the washer from the top and the door catch. If this fails to solve the problem, then you will need to buy a new unit. You will get one online from Seme Nedis Ltd. You will should find the washer model number on the outer edge of the door. I hope this has been of some help to you.
Nov 29, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
289 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
