Question about HP Officejet 5610 All-In-One InkJet Printer
Hi, I got an problem with my HP 5610 Officejet. Error was carriage jam after that paper jam. I disassemble printer and cleaned parts such as Silver road ( forgive me, I don't know exact name) also in strip for sensor and another one strip on paper roller on left side corner. But problems still exist. while give print paper stuck on middle also carriage struck on right side corner with noisy.... Please help me to solve this problem.. give me your solution at nsuarnie@gmail.com Thank u.
SOURCE: hp officejet 5610 all-in-one
hp officejet 5610 cd downlod
Posted on Jul 30, 2008
FixinFax
  • 3085 Answers
SOURCE: HP officejet 5610 - turn it on and it says
You have a bad printer unit. Uneconomical to have it repaired.
Sorry
Posted on Jun 04, 2009
mace1mace
  • 1138 Answers
SOURCE: My officejet 5610 says
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
Posted on May 23, 2010
vinay229229
  • 1121 Answers
SOURCE: How to clean scanner and roller on officejet 5610
No special tool to clean scan head,Clean with soft brush, open mechanism clean,lubricate it to avoid warn out. see the snap shot.. Where as roller part, clean with wet cloth on surface of the ADF rollers, & pick up rollers..
Posted on Sep 13, 2011
Encoder strip
will u clean paper feeder assembly, paper sensor ? will not ? clean paper sensor its a bottom of paper fee. assy
try other things.. change u r paper feeder assy.
change u r head carriage assy. cable. it has 20 pin cable.
change u r head carriage assy...
Sep 17, 2013 | HP Officejet 5610 All-In-One InkJet...
Exactly what parts am I cleaning for a 'carriage jam' on an HP Officejet 7310 printer
the carriage jam error is meaning the path that the printhead is sliding from side to side. You might have a small piece of paper causing an issue.
Dec 03, 2010 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Carriage Jam on my HP Officejet 5610v All-in-One printer
If I move the carriages to the center of the bar they slide on (would be the center of the paper) and close everything it seems to re-load, I've had to do this several times over the last few years and so far it always works
Feb 09, 2010 | HP Officejet 5610 All-In-One InkJet...
Carriage Jam?
Take a soft moist (not wet) cloth and clean the shining rod that the print cartridge slides on. Move the cartridge holde manually to clean complete rod. Dust from paper accumulates on it and thus hinders movement. DO NOT LUBRICATE THE ROD WITH OIL OR ANYTHING.
Dec 04, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
I am experiencing the same problem.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab56
Jun 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam Error Message
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
djiu9ofdfd22
Apr 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
