Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husqvarna chainsaw 440e - enough chain lube?
Husqvarna chainsaw 440e - using less than half a tank of chain lube to a tank of fuel - is this enough chain lube delivery?
  • Anonymous Mar 29, 2014
    won't start,has 0 compression,turn over with very little resistance ,spark screen appears clean,has spark, any idea what is wrong with it?
    President:
  • 2,220 Answers
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Posted on Oct 07, 2009
Testimonial: "thanking you"
  • dontbother10
    dontbother10 Oct 07, 2009
    Serial number decode – for use with IPL
    06 1500198
    06 = year produced – 2006 (single digit before 2000)
    15 = week produced - March
    00198 = 198th unit produced by Husky that week
  • dontbother10
    dontbother10 Oct 09, 2009
    You are very welcome. Thank you for your reply. Lou
  • 211 Answers
Hi
you can adjust the oil delivery from the bottom of the chainsaw
bye
How to replace gas vent on huaqvarna 51 chainsaw
Disassembly
The fuel tank vent is located on the right side of the fuel
tank next to the right rear rubber element. With the fuel
tank empty and the fuel hose disconnected at the
carburetor, remove the two rear rubber elements. Separate the rear of the crankcase and the fuel tank enough to expose the fuel tank vent. Working through the fuel filler opening, grasp the fuel tank vent tube with a pair of needle nose pliers. Push the vent out the other side.
For access to the right side rubber elements, first remove the chain brake cover, bar, chain, chain catcher and cover plate.
For access to the left side rubber elements, remove the starter housing.
Assembly
Install the fuel tank vent using a drift the same diameter
as the vent tube. The remainder of assembly is the
reverse of disassembly.
Nov 07, 2014 | Garden
Not enough oil to lube bar while running causing chain to over heat. When refueling the gas is empty but oil tank is over half ful yet. How may I make adjustments to solve this problem?
The machine should always run out of fuel before it runs out of oil, youhave not said what model this is, not all machines have an adjustable oil pump, some are just set for a certain length of guide bar, adusters on the oil pump increase the throw of the pump shaft so will be a slot head screw usually on the under side of the crankcase, there will also be a picture embossed into the tank with a plus and a minus, before trying to alter the pump remove the guide bar and chain and clean the the oil entry hole in the bar, and from around the bar pad.
Aug 14, 2011 | Husqvarna Chain Saw 20" Bar
Husqvarna 350 chainsaw problen..not enough oil getting on the chain
The 350 had a three position oil pump, the adjuster is on the bottom of the saw, under the pump on the drive side, there is also a filter in the base of the tank, it is held with a single cross head screw, you can see it between on the drive side, between the fuel tank, it is grey in colour.
Jun 29, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to adjust the carburator on a 16" 440e series husqvarna chain saw
Turn both jets all the way in.then turn them out 11/4 turns out.start it up and you can fine tune it from there by turning the jets in or out.
Dec 23, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 450, and I would like to increase my bar oil output. Where is the adjustment screw? Please!
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Nov 08, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
How much chan lubricant should be used and what is the grade of the oil
You want to buy Bar grade oil, it is sticky and stays on the chain, it will properly lube the bar and chain with a full tank o gas. People have used, used motor oil but this wears down the chain and gears from the micro sized filings in the oil so use clean bar oil to lube the chain correctly. also if the chain sprocket has a small hole in the tip of the saw you will need to buy a gear lube pump to keep grease in the gear at the tip of the blade. This should be lube each time you fill the fuel tank and once half way threw the tank of fuel to make the bar last longer. The bar oil is a special grade of oil and requires bar oil for it to adhere to the bar and the bar guides. Hope this helps and thanks for using fix-ya.
Jun 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw starts but engine cuts out after less then one
i think you really need fresh fuel, clean out tank as much as poss with new oil also. will probably take a while to pump fuel through
Mar 06, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 137 Chain won't stop when idleing. I turned the T screw down just enough to keep it running chain keeps on going. Could it be the clutch?
your carburator is gummed up. Get some carb. cleaner additive for your fuel, run a couple of tanks of treated fuel through the saw and it will be ok.
Feb 01, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
1,313 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
