the guy that im getting the tv from said something needs soldiered on the on/off switch it's a...
(More)
the guy that im getting the tv from said something needs soldiered on the on/off switch it's a pioneer 533hd5 53''
Hi, I am looking to buy a used 53" Pioneer rear projection TV, but the problem is: Once you...
(More)
Hi, I am looking to buy a used 53" Pioneer rear projection TV, but the problem is: Once you turn it off you need to wait an hour before turning it on again or it will blow a fuse. The fuse is easy to change, but what's the problem?
when television is turned on it turns right back off. we replace the fuse that was blown but it blew...
(More)
WHEN TELEVISION IS TURNED ON IT TURNS RIGHT BACK OFF. WE REPLACE THE FUSE THAT WAS BLOWN BUT IT BLEW AGAIN WHENT THE TV WAS TURNED ON AGAIN
This is a 4 years old projection TV kept in a good shape. Few days ago I tried to turn it on while...
(More)
This is a 4 years old projection TV kept in a good shape. Few days ago I tried to turn it on while the TV was on standby power (Red Lights on) it turned the green light on and momentarily it turned it off so the TV does not turn on. There is a clicking sound such as relay trying to turn on but it reverts to standby power again. Sometime I can do this using remote control but lately the remote control does not initiate this transition either. So far I could manually turn the standby power off and on to turn the green light come on for 1 or two second and it clicks and it turns off.
I opened the front standby switch the part # looks like ES892S. Does the remote on/off circuitry resides in this switch or it is located somewhere else?
