Question about Panasonic AG-1980 S-VHS VCR
Noisy video on tuner input
I have several of these decks, and a few have developed noisy video, but only from the tuner. The noise resembles a moving herringbone pattern. I've swapped out the tuner and mpx board with a known good one. I even swapped out the power supply. No difference.
Any ideas? Tracing the tuner video throught the deck is about as far as you can get from easy. The service manual offers little encouragement.
  • HadYourPhil Jan 14, 2008
    It doesn't seem to be the tuner. I was able to greatly improve the picture by replacing the caps on the timer/display board. Those are notorious for failing and darkening the display. I'll try the main power supply next. Those switch mode supplies can be a bear!
  • 579 Answers
Well, if replacing the tuner did not solve it, the next likely culprit is the power supply. Does it look OK on A/V cable input? You didn't say what brand this is but all the older Matshushita made VCRs (panasonic, sylvania, quasar, magnavox ond others) have power supplies that fail often in this manner spewing out noise that interferes with the video signals. Some of us know how to repair the supplies as they are usually not available for replacement.
Posted on Dec 28, 2007
How do I fix my noisy treadmill?
you must LUBE the deck belt, and lube the another parts, like roller bearing front and rear +drive belt maybe need replace. see the video attached.
Jun 08, 2013 | Proform 785 CS Personal Trainer Treadmill
When I engage the mower blades it makes a nasty noise, like a bad bearing. I checked the brakes, belts, etc and all is well. Any thoughts?
hi there mrswp211
check out the pulleys from the pto to the deck for noise - if rumbly / noisy replace them , if not
remove pto to deck belt ( make note of belt routing 1st ) then rotate blades and spindles by hand give a good spin you should hear if noisy , grab blades and try to move them fore/ aft to see have movement if they do and they are not smooth and quite spindle bearings are the problem
generally if unit is noisy only when deck engaged bearings will cause this
but make sure pulleys on the top of eack spindle good to and everything is tight
a badly slipping vee belt will make a squeeling noise and somtimes will make the unit shudder
you will have to remove deck to replace bearing(s) , from experience replace mandrell/ spindle assys do both at same time because if one has gone the other wont be far behind - both do same milage and work and quite often if replace bearings only they dont go back in tight .
cheers hope it helps
pauly46
May 29, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have 2009 D22 double cab it has done 43 000Km, however I have two concerns. The first is noisy tappets usually only when the vehicle has been standing for a day or two, however it only lasts for a few...
If the vehicle has had proper oil changes,the noisy valve lifters may the oil filter.If the anti-drainback valve is defective and the filter is at an angle,it may take a few extra seconds to refill before can supply the engine with normal oil pressure.
Also,at the last oil change,has the proper oil viscosity been used?
The noise at the dash is usually a hose.Have someone move the hoses a little while you sit inside and listen for changes in that noise at 2000 to 3000 rpm.As it becomes quiet,adjust the hose or whatever that new position.
May 12, 2017 | Nissan Pickup Cars & Trucks
Dryer has started to be very loud.
Check ease of drum moving that it moved freely. Remove panels Is motor noisy? Check belt. Is movement of drum noisy? Make sure exhaust is not clogged. Can the air move freely to the outside. Make sure there are no kinks in exhaust line. Determine cause of noise then you have a few choices. Repair, lubricate replace parts or replace dryer. Sometime you just need to use it until it doesn't work anymore and then buy a new one depending on the cost of repairs vs. replacement.
Sep 30, 2010 | Fisher and Paykel Dryers
Noisy when agitating. has not been moved
Noise comes when some part of the moving part is getting collided or getting stuck somewhere. Try cleaning the wash cycle and the rinse drum. It is the only cause of noise. Thank you, Sir to visit Fixya.
Sep 17, 2009 | Washing Machines
DRYER IS MAKING A CONSISTENT BANGING NOISE WHEN RUNNING. DRUM IS TURNING AND DRYER DOES DRY OK.
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
Record Local audio news tapes for Blind residents.We have Two decks and both now noisy; although finished tapes not effected - YET I believe Decks need expert service
Can you give us where you are located so we can give you pointers? What kind of decks? Make and model please. Also, what exactly do you mean by noisy?
Thanks,
Dan
Oct 02, 2008 | Audio Players & Recorders
Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Apr 09, 2008 | Audio Players & Recorders
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Panasonic AG-1980 S-VHS VCR Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
