Question about Water Heaters
What type of gear oil goes in 1997 freightliner with a6 speed eaton fuller
  • armstrong_mi Oct 07, 2009
    what the weight for the synthectic gear oil
  • Water Heaters Master
  • 3,051 Answers
Hello there:
here is a link to the exact same chart that we use at warner transportation this covers all makes and models yours is listed at the right as you lkok through the list ok it is in pdf format once it opens it will show you a picture of a shell than it will open the page ok?
  1. [PDF] Shell Lubricants Product Data Guide 495k - Adobe PDF - View as html Heavy-duty synthetic gear oil. Shell Spirax GSX 50 is blended using ... Eaton, Eaton Fuller, ZF, Dana, Rockwell. amongst other: • Powershift Transmissions ...shell.com/static/au-en/.../heavy_duty_gear_oils.pdf
  2. best regards michael
Posted on Oct 07, 2009
  • Michael Thomas
    Michael Thomas Oct 08, 2009
    Hello again
    the synthetic oil is a 80w 90 gear oil ROTELLA is the well known manufacture for this type of oil and if you are close to a reputable truck center they will have this too ok?
  • Michael Thomas
    Hello again here is some more information for you
    Shell ROTELLA® Heavy Duty Gear Oils
    Shell
    ROTELLA® Heavy Duty Gear Oils are highperformance multigrade gear
    lubricants formulated with an extreme-pressure additive for good load
    carrying capacity and protection of gears. They are suitable for
    heavy-duty truck and automotive differentials, manual transmissions and
    oil lubricated wheel bearings, drive-train gears of heavy-duty
    automotive, trucking and off-road equipment operated under
    high-speed/shock load, high-speed/low torque and low-speed/high torque
    conditions. Shell ROTELLA® Heavy Duty Gear Oils meet the requirements
    of API GL-5 and MIL-PRF-2105E and are available in two SAE viscosity
    grades: 80W-90 and 85W-140.
    regards michael
    Sniper:
  • 168 Answers
Synthetic gear oil is used in a 1997 Freightliner
hope this helps
1L code? How to reset ?
can we have make and model please and a fuller description of the issue. Do you have an owners user guide for the unit?
Jun 08, 2016 | Water Heaters
Tip
How does circuit breaker work?
In the circuit breaker there are two electrodes with space some distance.
There are many types of circuit breaker air blast,oil C.B, vacuum C.B etc.
Most probably oil circuit breaker is used. In the OCB, the transformer oil fill.
And these electrodes are submerge.
Now when the electricity flows from one terminal to another terminal, the arc is developed between terminals end inside the circuit breaker. This arc is quenched by transformer oil.And the electricity flows without any fault.
on Mar 04, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Installing new flomaster xp2 pump. what color wies
Are you asking about the cord from themotor to the control? If so It should either be Green Black and white or all those plus a red. The green is the ground and it goes on the green screw. White goes to the common or line(1) post, and usually red is Hi and Blk low for the speeds. If it is a single speed only no red and black will go to the other line(2).
If this does not answer your question please post a comment with what wires and where you are dealing with.
Dec 18, 2009 | Water Heaters
The pilot goes off and on and does not light the burner
ok make sure u turn everthing thing off then wait 5 min then turn the dail that controls the heat on it to pilot light then turn the gas nob to pilot then ignit it once lit wait a few seconds and turn gas nob to on pisition then turn heat dail to were the arrow is not to a b or c cause the gas is to high it will blow it self out
Nov 17, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
How do i clean out my system for my oil hot water heater? some how we ran out of oil, i guess we used way too much oil, it usually lasts until november but went out mid sept, i had oil delivered and now it...
It sounds to me like you probably have a clogged oil nozzle. Of course I'm am assuming that you bleed all the air out of the oil lines that run both to the hot water tank and the heating appliance. If you have solid flow at the water heater pump, and the unit still does not ignite, it is most likely the nozzle. Hope this helps
Sep 14, 2009 | RTO Bock Water Heaters 51E 50 gal 152,000...
Is an oil burner efficient for a detached 2 car garage w 1 BR apt
the best oil burner to use would be of the condensing combination type as this would be abt 96%efficient and only heat water as you needed it probably saving you abt 30% on your oil bill
Nov 12, 2008 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Starting a pilot light on a hot water heater
Hi blaineandhea,
I'm Harvey the Master Plumber.
Your statement is: You ran out of oil,so got more oil in tank.blead the lines.but now you cant get pilot to start
Every oil burner I ever worked on had a type of spark ignition. No standing pilot. If this is the case for you then the only reason it won't turn on is that the lines weren't properly bled. It only takes a little bubble to ruin the day. Don't be afraid to blead lots of oil, you should be catching it anyway to put back in the tank.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Water Heaters
Water Heaters Logo
89 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
