Question about Mitsubishi WS-55805 55" Rear Projection Television
Picture Problem I have a Mitsubishi 1080 series TV Model WS-55805. The picture is starting to convex and I'm seeing all 3 colors of red,blue, and green. Any suggestions on how to fix the problem? Is it something that I can do? or will I need a TV repair person for this? If so, how much would something like this cost?
  • 4 more comments
  • jim j Jan 17, 2008
    i have the same problem. did you get it fixed? what was your solution?
  • kcfree Feb 20, 2008
    I have the same problem and I don't know what to do about it. These TV's cost too much for this to be happening in a a 4 your period.
  • Bimmer Man Mar 28, 2008
    I have also recently developed this problem. I purchased my TV used 2 weeks ago and it looked great until last week. it almost seems that you are seeing the picture in 3-D, only mine it at the top of the screen. I used to work for a home theatre reatiler several years ago and sold, installed and set up convergence after TV delivery. This was the first thing I tried to do since the tv was recently moved to my house. This seems to be a convergence problem no doubt but it is not going to change by setting the convergence. Does anybody have a solution? Any help would be greatly appreciated.
  • Anonymous Mar 29, 2008
    Add another consumer to this list. I've had mine for over 6 years and begining to experience the problem now. Auto convergence did nothing for me. I took off the back and vacuumed out all the dust (not really to dusty), still no real improvement. Seems to me that some electrical part is wearing out. So now is it better to have this repaired or buy a newer T.V.?
  • toddbeestang Nov 11, 2008
    Mine is about 6 or 7 years old and looks like 3-D. Color alignment problem. It looks like the convergence is out but curves from top to bottom. I make a fist and hit the TV frame on top near the corners, sometimes on the sides and it often fixes it but it's annoying to have to do this. Once the TV is working fine we just leave it on all day so we don't have to pound on it again.
  • Anonymous Apr 19, 2009
    I am having the same problem ??? Did anyone get this repaired. We are not sure if it is worth it to fix the TV or save for a new one.. They cost so much???
Make a fist and pound on the outside frame at the top corners, both on the top and sides, sometimes in the middle. NOT the screen itself but the frame. It knocks the convergence back together. Sometimes it changes the direction of the convergence problem but if you hit it in another area it will straighten it out. This will not solve the problem forever but will work for about a day. I do this everytime I turn the TV on. Best part - It's free. I'm just milking as much out of my TV as possible until it dies and I buy a new Plasma.
Posted on Nov 11, 2008
There is a Convergence option in the Menu under Advanced Options. It allows you to set the colors so they line up. I've had my TV for about 6 years and I need to do it every week or so now.
Posted on Feb 22, 2008
I have the same problem. what was you solution? did you get it fixed?
Posted on Jan 17, 2008
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
What universal remote control is compatible for the mitsubishi 1080 hd series i belive mine is 55 inches? i need to align the red n blue crosses so my picture is not blurry.
ANY mitsubishi remote will work, universal remotes will not do the job.
Is color skewed and or 3 d looking?
The more you tell me the better I can help you.
Sep 15, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a Mitsubishi HD 1080 55
Your unit has some sort of Thermal problem either with the PSU fault, or a thermal problem elsewhere that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. T
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Mitsubishi WS-55805 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a WS-55805. Was working great, then suddenly no picture, just audio. When I press the Menu button, I get the menu but I see three separate colors for each menu item. Could this be the lamp, or...
This TV does not have a single lamp but a set of CRT tubes.
If you get menu displayed on wrong clors or colors are not matching then it is either a bad CRT, a bad CRT high voltage power board, or sometimes a problem with convergence board and convergence ICs, however in this last case you usually get no picture and no sound .
You can get service manual from link below:
Mitsubishi - CRT Projection Television - WS-55805 Service Manual
Apr 10, 2009 | Mitsubishi Televison & Video
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Dec 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Geometry - Edges cut off
1)power on TV
2)Push menu-1-2-5-9 in quick succession
3)Use 4-5-6- to change colors
4)Use enter to blink / unblink cursor ( blink = move, unblink =
adjust )
5)Finished? = menu out to save changes
Please rate this solution......................................
Nov 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
290 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
