Question about Linksys Wireless-G WRT54G Router
My ip address should be 192.168.1.1 in the setup tab inlynksis but isn;t how do i change it manually
  • 2,260 Answers
The default IP address of the Linksys router is 192.168.1.1.
First check the IP address of your computer.
START ==> RUN ==> type cme and hit OK==> you will find the command prompt. Type " ipconfig " in the command prompt and hit ENTER.
Now you will find the IP address and the Default.
Default Gateway is the IP address of your router. with this number you can open the set up interface of the router. and change the IP address of your router.
For more info about networking Click Here
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
    President:
  • 2,049 Answers
Linksys routers come with 192.168.1.1 as the default IP address for the router. Here's a good article on changing the IP addresses within Linksys.
http://www.dslreports.com/faq/6742
  • Linksys Master
  • 8,404 Answers
Why - are you set up for static addresses??? Let the routers manage themselves in this respect.
If you must change it, get Network Magic free down load of eval version. Read the deal at the website.
I use the pro version and I love it ... but IO let the modem and routers (I have 5 in my network) manage themselves.
I am not a Cisco employee
I hope you will get this software. It will make your network duties simple.
a
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Thanks,
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
Linksys WRT160N bad wifi
Please check on the status tab that the what is the internet ip address you are getting from the page.
The ip adress is if 192.168.1. then you have to change the router ip address to 192.168.2.1 on the very first page setup under the router ip address.
Jun 07, 2012 | Linksys WRT160N Wireless Router
Dir-615 router wants a username and password to access webpage. I do not have that. I tried reset button 10 seconds on back of router. I tried admin. no luck!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
3714-015.pngNOTE: If the IP address of the router has been changed, type the router's IP address in the "Address" bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
    NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router's password ("admin" is the default password), then click OK.
3695-005.png NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
Step 4:
When the router's web-based setup page appears, click the Wireless tab and select the Wireless Security tab.
Step 5:
For the Security Mode, select WEP.
Step 6:
For Encryption select 104 / 128-bit (26 hex digits).
Step 7:
For the Passphrase, type a wireless network password of your choice such as "MySecretKey," then click Generate.
NOTE: Your password should be unique and can be a combination of numbers and letters of up to 16 characters.
Step 8:
For the TX Key, select any number. This will determine which key you'll be using. In this example we selected number 1.
Step 9:
Copy Key 1 as this will be the key to your wireless network
Now try , this should work..
thanks for rating good luck
Jan 15, 2011 | Computers & Internet
Hi, i have already installed and all is running fine however i didn't secure the network and now need to add a password how would i do this ?
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Copy Key 1 as this will be the key to your wireless network.
Step 10:
Click 4058-005.jpg.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | D-Link DIR-615 Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I need to change my NAT settings from moderate to open and dont' know how to do that.
A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Enabling DMZ: 1. On the left side of the setup page, click on the WAN Setup under Advanced tab. 2. Check the Default DMZ Server and specify the IP address of your computer. 3. Click on the Apply button.
Jun 04, 2009 | NetGear WGR614 Wireless Router
Just bought a laptop and can't get comcast to work with net gear. My son's lap top worked when he lived with me.
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 10, 2008 | NetGear WGR614 Wireless Router
Dynext router
Aug 09, 2008 | Dynex Computers & Internet
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Setting up wireless connection
May 14, 2008 | Buffalo Technology WHR-G54S Wireless...
Linksys Wireless-G WRT54G Router Logo
247 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
