Question about HP Officejet 7210 All-In-One InkJet Printer
Network Interface Hi, I have a problem with my 7210 all-in-one where suddenly it is not recognized by the ActionTec wireless router. I was working fine until one day when I went to print and it failed. I tried a power reset of the printer and the wireless router. I set the printer back to factory defaults but when I try to reinstall the printer it can't be found on the network. What else can I try. It seems like the network interface has failed for some reason. Does that sound like a feasible diagnosis? Thanks, Richard Abt
  • 1,031 Answers
Test the printer network cable for connectivity,but if the network interface fails u can use other ports like the usb port with the usb network interface adaptor to connect to the network once uve confirmed that the RJ45 network interface is bad
Posted on May 07, 2008
I have an actiontec gt704wg wireless router (from my previous Verizon DSL service)...I now have a Netgear CGD24G wireless router with Brighthouse roadrunner service...I want to connect my actiontec router...
unfortunately, no. You would be better off Ebaying the actiontec and getting a dedicated router- the reason is that the only uplink on the actiontec is the dsl port- not ethernet. Theoretically you could mod the firmware to make the wireless an access point only- but it would still have the achilles heel of needing an uplink.
Mar 21, 2011 | Actiontec GT704WG Wireless Router...
I cannot find my wep key.
When you configure the "wireless" interface inside the router, you define:
* SSID -- the "name" for your wireless network
* encryption-level -- use 'WPA' or 'WPA2', not 'WEP' (too easily "hacked")
* the password for your wireless network.
Then, on your wireless device, select the SSID, and enter the password, to connect.
Mar 06, 2011 | Actiontec (5GE583000-01) Router
How can I disable my actiontect GT704WGR wireless setting? Verizon personnel has enable the wireless setting of my modem actionteck GT704WGR 2 days ago. Now I would like to disable it because I will use...
you can login to the Actiontec modem by typing the ip address of actiontec modem in the address bar of Internet explorer...
It will open the interface of actiontec modem...
In the Interface of actiontec modem you will have option for wireless...
If you look under wireless setting you will be having the wireless mode as 802.11b/g/n or just B/G/N....
Change this wireless mode to OFF...
Thats it you are done...
By default the ip address of action tec is
Dec 13, 2010 | Actiontec Electronics (GT724WGR) Retail...
Wireless capability not turned on
Turn off all PC's that are attached to the router. Try unplugging the router for at least two minutes and plugging it back in, then try to turn the wireless back on.
Jan 02, 2010 | Actiontec (GT701WG) Wireless Router
Cannot connect a wireless Toshiba 6100 laptop
With an Ethernet cable, connect the "wired" port on your laptop to one of the "wired" ports on the router.
Access the router's built-in web-interface, and run the "Wireless Networking Setup Wizard" to configure your wireless network.
Dec 28, 2009 | Actiontec GT704WG Wireless Router...
Using the Actiontec GT704WG as just a router with comcast's cable modem. Seem to have a configuration problem. I am not sure what I am doing wrong (connections, configurations, etc) Devices are recognizing...
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
Dec 23, 2009 | Actiontec GT704WG Wireless Router...
How can I activat my wireless connection in my
You will need to check the wireless settings of the router.
For that, you will need to access the set up interface of the router.
Here you can change the wireless network name and secure the wireless network.
Click Here to know more about route set up
Oct 28, 2009 | Actiontec (GT704WG) Router
No wireless connection after powercycle
Sounds to me as if the Actiontec GT704WG has died. If it is still under warranty, get it serviced. If it is not under warranty, You can try to find en electronic friend to take a look at it. If you do not have such a friend, Maybe someone else here can help you. But you might want to consider a new unit.
May 31, 2009 | Actiontec GT704WG Wireless Router...
Asking for password, but never needed one before
If you are referring to the web interface, the default settings are:
Username: admin
Password: password
May 14, 2009 | Actiontec GT704WG Wireless Router...
Seeing whose on my network
im using an actiontec GT704WG Wireless router
Feb 03, 2008 | Actiontec GT704WG Wireless Router...
HP Officejet 7210 All-In-One InkJet Printer Logo
120 people viewed this question
Ben Johnson
