Question about Maytag Neptune MAH5500B Front Load Washer
Washer will not spin; displays nd error
Washer starts to spin for about 2 seconds, stops spinning but timer continues to count down to zero, then error code displays "nd". This happens on the spin cycle and 2 different wash cycles we have tried. Could not find any troubleshooting info of value in the owners manual. What does nd mean?
  • 3 more comments
  • APWheets Dec 24, 2007
    Great website, fast help, thanks so much!
  • paulacraig Jan 13, 2008
    We have the same display of nd on our washer. when the drain pipe was taken out of the main drain out of the house the machine drained out. So there doesn't seem to be a clog in the drain pipe. The pump seems to have rust around it. My husband can't seem to find much info on the machine at all forget about specifics about the pump
  • Anonymous Jan 19, 2008
    I was washing a load of towels when the washer sounded funny. The code nd appeared. Don't ever open the door when that appears, because I did and water and suds came spilling out on the floor! I tried putting it on the spin cycle, it ran for about 8 minutes, and the nd code came up again. It's Saturday afternoon and the appliance store where we bought it is closed. The drains in our house are working and we can't see any kinks in the hose. I guess we'll wait until Monday and call a repairman.
  • lorilangford Mar 07, 2009
    My maytag neptune washer won't fill until the bleach cycle and I am getting ND on the control panel. Thanks
  • Anonymous May 04, 2009
    Washing machine reads an error of ND and it wont continue any cycle and the door remains lockeed. What to do?
CHECK THE PUMP. I had the same problem and after removing the pump (fairly easy) found a clump of stuffing from a hole in a quilt jammed in the impellor. After removing and installing the then cleaned out pump it worked perfectly. Suggest using a regular stainless steel hose clamp in place of the factory clamp that is hard to put into position on the hose to the pump. Be sure to put the clear plastic bag back in place over the pump assembly to protect the pump from water damage.
Posted on Feb 01, 2009
  • 298 Answers
(nd) stands for no drain check the pump,and drain hose
for clogs
Posted on Dec 24, 2007
I have a kenmore front load washing machine that water shuts off after 5 seconds. Timer continues to count down but nothing happens in the machine. Timer also takes about 3x longer to get to zero.
Troubleshooting Appliances: Washing Machine and Dryer ... > Blog > Articles
Sep 16, 2012 - If your washing machine or dryer seems ready to give up the ghost, follow ... When you start your washer, a solenoid-operated water inlet mixing valve ... Afront-loading washer lacks the agitator, instead using the tumbling ... Clothes Remain Wet After the Spin Cycle. 1. .... Bought washer/dryer second hand.
Oct 19, 2015 | Kenmore Washing Machines
Frigidaire frfw3700lw0 drains but not spinning
Hello ctilton2001 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 06, 2012 | Frigidaire FRFW3700LW Washer
Washer appears to be going throught the wash cycle but the counter is not counting down and it goes no further than the wash cycle. Just continues to do this the whole time. Model # FAV6800AWW
Here are some handy links if you are going to DIY the fix.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Are there any unbalance error codes to the LED display such as dC or uC?
When the washer stops can you place that wash load to a Spin Only Cycle and let me know if the Spin Only cycle completes. Are there any large tub swings in Spin Only cycle with that wash load that cause the Spin Cycle to stop with error codes dC or uC?
Let me know if you can to do some troubleshooting. It would require front panel removal so we can watch the Motor and verify it will rotate the Clutch Pulley CCW in the Spin Only Cycle. If you want to troubleshoot I will give you additional info to begin the process…….Rich
Apr 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Cycle Signal Volume
Try this, with power off press spin for five seconds on and five seconds off until 88 appears in the display. After this either it will start with a c1 or it will flash an error code, write down the code and within five seconds press spin again to advance so auto diagnostics will start, if your display is bad F 2 will pop up quickly. Let me know, SearsTechToo
Oct 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Washer door will not open
Iv, did you check the pump to see if it's jammed? The SC indicates there is a failure in the washer. While you are in the service mode, press the rinse and spin button while rotating the cyle select knob one click. A d should show in the display. Rotating the knob again will show the latest error code. When you get the code post back or e-mail me at and I will try to get to the bottom of it...Catriver.
Dec 02, 2006 | Maytag MAH8700A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
630 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
