Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 water leaks from lid during final spin cycle
Water has started oozing out from under the lid and leaking down the front of the washer during the final spin cycle. Any ideas? I've pulled the pump and checked all hoses for blockage and found none.
  • 3 Answers
Is the machine level
Posted on Oct 09, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
My Fisher Paykel gw612 leaking water from underneath during the spin cycle. I can't see any leaks underneath and the hoses and side of the machine stay dry. Also when it is filling it makes a slight...
my quess its a big job, check to see if there are any leaks from the motor, you may have faulty seals, also check the water seals around the electroncis board, once water gets into the motor it becomes a big job. i need more info.
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
During spin cycle water on floor from outside
SEAL IS MOST LIKELY LEAKING BETWEEN AGITATOR AND DRUM, SEALS ARE CHEAP AND DEDERGENTS OVER TIME CAN WEAR THEM OUT.
May 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
4 year old Fisher Pakel washing machine
Hi and welcome to FixYa!
Some things to check- Start with the water pump underneath the machine in the right-front of the unit. Look for signs of rust or leakage, that would be the most likely cause. Also check the operation of the diverter valve, inspect it to make sure there is not something like a lint ball or small object caught in the flapper; this can allow water to seep out of the diverter when it is supposed to be sealed in the spin or drain cycles and this seepage will get on the tub's rim as it spins and cause a leak on the floor. This kind of leak will cause water to appear as if it is leaking between the top and the cabinet.
Word of caution- the water pump is electric, and if you allow this leaking to continue, it can actually short out boh the water pump as well as the machine control.
If afer you solve the issue, if you find that I have accurately described the problem, a FIXYA rating is greatly appreciated. Thanks!
Feb 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
570 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
