Question about Philips Xenium 9@98 Cellular Phone
Philips Xenium x710 messaging
I have a problem receiving text messages when using my x710. My 'phone will receive a message and display "1 new message" but will not let me see it. I have to switch my 'phone off then on again and wait for it to lock itself, only then will it open the message. Very annoying.
  • 279 Answers
SOURCE: philips shoqbox
You have a file error: a system file may be missing or you have a format error on the SHOQBOX. To fix this problem: 1. Connect the SHOQBOX to the computer using the supplied USB cable. 2. Plug your SHOQBOX into a wall outlet with the supplied AC adapter. 3. Launch the Device Manager at Start->Programs->Philips->Philips->PSS110 (or the model number of your SHOQBOX) on your PC. * IMPORTANT: All music & content of your SHOQBOX will be erased once the factory setting is restored. 4. A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting. 5. Follow the on-screen instructions to complete the restoration. 6. The Device Manager will close automatically once the success message is displayed. 7. Transfer a couple of songs into your SHOQBOX to confirm if the SHOQBOX has fully recovered all the files. 8. Close all opened applications and safely remove your SHOQBOX by clicking on the icon on your Windows task bar tray. 9. When prompted, ?The USB Mass Storage Device can now be safely removed from the system?, click OK and unplug your SHOQBOX. 10. Your player will display ?UPGRADING FIRMWARE?? once disconnected from the computer. 11. After firmware upgrade is complete, it will reset itself, showing the PHILIPS splash screen. 12. Press to switch on the player again.
Posted on Sep 12, 2007
  • 4 Answers
SOURCE: Disk Recover message and trays are locked
I have had the same problem. To reset the machine when this happens: 1.Switch off with front panel switch (display dims, but still shows same message). 2. Switch off at mains socket, leave off for about 15 seconds. 3. Switch on at mains socket then front panel - machine should then start up as normal.
I have experienced the "disc recover" condition several times now, when a radio recording has run to the end of a disc, and for some reason the recording process has not terminated properly, resulting in the loss of the recording. I found by trial and error that if you switch the mains off at the socket without first switching off at the front panel, then the disc can become corrupted and useless.
I suspect it is partly dependent on the make of disc as my current batch of TDK RWs do it almost every time, whereas with my last batch (can't remember if they were Maxell or Memorex) seemed much better.
I think the only way to prevent the problem is to manually stop the recording before the end of the disc is reached, I suspect possibly before the 74 minute 'red-book' CD limit is reached, even on an 80 min. disc, though I haven't yet tested that theory properly.
Hope this helps,
HifiJohn
Posted on Oct 03, 2008
  • 191 Answers
SOURCE: TV displays a "no signal message"
is there any picture at all ? if no signal message regardless of any signal input , ur ad board need to be change.
Posted on Nov 10, 2008
  • 35 Answers
SOURCE: Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Posted on Mar 05, 2009
SOURCE: Philips VLounge crash on open.
I have the same problem with my philips spc620nc . Have tried philips support. no response. Almost 1 year since first inquiry.
Posted on Dec 13, 2009
MyTouch phone will send texts but will not receive them.
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 10, 2012 | T-Mobile My Touch Cell Phone
The message inbox says I have 1 new message, even though I have deleted all messages and there are no unread texts. It also displays the small envelope icon on the main screen in the bottom left corner,...
go to the mesage tab and click options then search for the option on the sim mesages and when it opens delete all the messages in the sim message box and check whether any messages in the outbox
Jun 23, 2011 | Samsung Renown Cell Phone
Everytime I try to send a text message, it tells me that the message failed and if id like to retry. Under the message info it says that the message wasn't sent because of a temporary service not...
It looks like you don't have good reception where you are trying to send and receive text messages from. How many bars does your phone display show?
Dec 12, 2010 | Cell Phones
Have to restart to receive text messages.
This is a glitch that I'm sure is Nokia's fault, let's keep our ears open on a possible solution to it soon.
Regards
Mar 30, 2009 | Nokia E71 Smartphone
When i receive messages on my i9 the number appears not name
I have the phone and have had the same problem. I found I have to add the "1" before the area code to all the saved contacts or at least the ones you use most and that should fix it... when the text message is received it has the "1" normally we don't save the number that way...
Feb 14, 2009 | Dual Electronics CECT P168 Cellular Phone
Can I receive and manage text messages on my parrot ck3200ls
Hi, no you cant receive and manage text from this handsfree, the signal strengh is displayed if the phone allows it, some phones will display battery and signal, some only battery etc.
Hope that helps
Oct 17, 2008 | Parrot Ck3200ls Lcd Color Display For...
Message icon and alert
you will need to contact your mobile provider and explain it to them and have them correct that on their network.
Sep 19, 2008 | Nokia 6120
Pan Tech Duo... New Texts and Silent
After you read a message, always hit the return/back key to get you back to the main list of messages. This phone automatically returns you to wherever you left off last, so if you don't hit the return key, your last message read will be what is displayed when you hit your message key.
No, your phone is not defective, you need to change your settings.
In your menu, go to SETTINGS, then PROFILES. Scroll to the profile you are using then select EDIT. Under each profile you have the option to select how your phone handles any alert you receive (i.e. for calls, messages, texts, etc.) You have several options some of which are silent, silent and vibrate, vibrate only.
Personally I want my phone to vibrate when it's on silent so that I know I'm receiving a call or text. You can choose another option though.
Jul 31, 2008 | Pantech Duo Smartphone
Philips Xenium 9@98 Cellular Phone Logo
48 people viewed this question
Top Philips Cell Phones Experts
Jack Frost
Vladimir Frolov
Tom Chichester
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
