Question about Cameras
My s-10 blazer's security light comes on andnow it
My 1998 s-10 blazer's security light comes on and now it does'nt want to start and light blinks
  • 422 Answers
SOURCE: Security light blinking
take it to a shop and have them diable the security system
Posted on Aug 26, 2008
66 chrgr
  • 1011 Answers
SOURCE: won't start, security light blinks for 10 minutes
there is a computer chip in the lock cylinder that goes bad ,so change the key and cylinder,then leave new key on until the light stops flashing about ten minutes this will set your new key to the security system hope this helps
Posted on Feb 07, 2009
  • 202 Answers
SOURCE: security light comes on in 1998 s-10
Your truck has what is called VATS Key or vehicle anti theft system. There is a small chip that is in your key. This chip has a set resistance that the computer measures. If there is moisture on the key, it can cause this, but the problem is likely either in the tumbler switch, or with the key. If you do not want to take it to the dealer for the repair, you can actually buy a kit online to bypass the VATS key module. (it will come w/ instructions.) If you have another key, try it to see if it has the same problem. If not, then it's the key. If so, the problem is either in the tumbler switch or the VATS module.
Posted on Mar 29, 2009
seanpwright
  • 2030 Answers
SOURCE: how do I wire my 1998 s-10 blazer for a trailer?
you hook the wiring for the trailer into the wiring harness in the rear for the tailights
this is best left to someone that knows what they are looking for in the wiring...consult your owners manual or take it to a good mechanic
Posted on Aug 27, 2009
  • 24 Answers
SOURCE: truck just quit starting got
Check the starter
Posted on Dec 31, 2010
Security light
When security light flash truck wont start, put ignition on and wait 10 minute security light will come on solid now it reprogram itseft truck will start, you will need a new key cylinder make it code to your key at the dealer
Apr 03, 2014 | 1998 Chevrolet S-10 Pickup
Blinking security light
try leaving key in run position see if it stops blinking could take up to 30 minutes turn off then back on when the light stops flashing. usually car will not start with security flashing mine will not but this will reset security.
Mar 14, 2014 | Blazer S10 1999 99
1998 Chevrolet Blazer LT 4-Door, 4.3 Liter/V6 engine. Security light stays on and will not go off. How do you get the light to turn off?
Try turning the ignition on ( but don't start ) and push the drivers door unlock button. The light should go out. Good Luck.
Jan 04, 2011 | 1998 Chevrolet Blazer
I had my ignition cylinder & housing replaced now my car won't start. How do I reset the passlock system so my car will start
Hello, Try this: Get in car, turn the key to start, when it don't start let key come back to run (do not turn off) The security light should be blinking, let car set for about ten minutes or until security light stays on steady at that time turn key off for 10 seconds then turn back on (do not go to start) security light will be blinking again wait 10 minutes and security light should go out. Turn key off, wait 10 seconds . Turn key on (do not go to start) security light will be blinking again, wait 10 minuets and security light will go out. AT THIS TIME TURN KEY OFF FOR 10 SECONDS THEN START THE CAR.
Sep 14, 2010 | Saturn SL1 Cars & Trucks
1998 Malibu passlock repair?
Security light is blinking? Leave the key on for 10 minutes until the security light stops blinking. Then try to start the car.
Jul 04, 2010 | 1998 Chevrolet Malibu
98 blazer odometer,temp goes out battery light comes on
sound to me like there a short in a fusable link somewhere and the computer could be involved.
Jul 11, 2009 | 1998 Chevrolet Blazer
1998 S-10 tuck runs good,then few days later when the truck is turned off wont start,cranks good,changed fuel pump and filter,its getting fuel and spark theres a security light comes on,then sits for few...
Hey have you recently changed your head unit. I have a 2000 s10 2.2 and i recently hardwired my pioneer 4000ub head unit and the security light came on upon not starting. every time you try to start the car while the security light is on it will add 10 minutes onto your time. For the security light not to come on you need to check your wiring. just remember dont keep trying becuase it wont work!!! find the problem and fix it.
May 09, 2009 | 1998 Chevrolet S-10 Pickup
Chevrolet Blazer s-10 1997, has fuel pressure and spark but doesnt start. It starts when you spray injector fluid into throttel body. I was thinking it could have clogged injectors but im not to sure....
use noid lights to see if injectors receiving power. you disconnect injector connector .hook noid light to connector to see if it blinks when you crank engine. if light blinks . you are getting power the injector is not working..if you get no light you have a open in wire. if the light on steady not blinking you got ecm problems .also check injector fuses.
Apr 27, 2009 | 1993 Chevrolet S-10 Blazer
2000 Alero Security light flashing and wont start
With the new lock cylinder in it, turn the key on. The security light should blink. Leave the key on for 10 minutes, the security light will quit blinking and go out after 10 min. This will reprogram your security system and the car should start. Also leave a battery charger on it while the key is on, If the battery goes dead during the 10 minute reprogram sequence, you will have to start over again.
Mar 08, 2009 | 2000 Oldsmobile Alero
Starting problems.
its either fuel or electrical
Jul 28, 2008 | 1998 Chevrolet Blazer
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
