Question about HP ScanJet 2200C Flatbed Scanner
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi, Reading other comments about VISTA not supporting the HP Scanjet 2200c (Scanner), does that mean it wont also work for windows 7 too?
  • Mukesh Chander Aug 07, 2013
    Drivers for HP 2200C Scanjet scanner for windows 8 where to find?????
  • Cherwally
    Cherwally Dec 01, 2018
    The original drivers are compatible only with Windows XP 32 bit at best.
    But i found that Vue Scan software will work just fine with old HP scanners and not needing any extra special drivers.
    Unfortunately is not a free software.
    But give a try also to this app (Freeware)https://www.softpedia.com/get/PORTABLE-S...
    New Friend:
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Posted on Nov 18, 2014
    New Friend:
It works in Windows 7 environment! I've tried it with HP PrecisionScan LTX from HP on my windows7 machine, (didn't work with vista) without using Win7 xp emulation or win virtual pc. just run the program (HP scan LTX) under winxp sp3 compatilbilty mode (>properties>compatibity tab) and runs as administrator.. you should be fine.
Posted on Jan 17, 2010
  • Roger Nathan Jan 28, 2011
    Did not work for my Windows 7, 64-bit version.
    President:
  • 2,049 Answers
There's hope ... Microsoft has announced an XP emulation mode... This is from Microsoft
"Windows XP Mode is specifically designed to help small businesses move to Windows 7. Windows XP Mode provides you with the flexibility to run many older productivity applications on a Windows 7 based PC.
All you need to do is to install suitable applications directly in Windows XP Mode which is a virtual Windows XP environment running under Windows Virtual PC. The applications will be published to the Windows 7 desktop and then you can run them directly from Windows 7."
Why not try it and see what happens!
Posted on Oct 07, 2009
  • mgprins Apr 15, 2011
    Hi, just for the record (previous remark was posted 2 years ago :). I got HP scanjet 4300C working on a windows 7 home premium 64 bit machine, using VMWare player (freeware found onhttp://www.vmware.com/ ). I installed win98 (using old CD I kept) on a virtual machine. Sounds complicated, but is in fact doable (for a nerd like me). Make sure your "USB arbitrage service" (or something like that) installed by VMWare is running.
    I admit: it is quite an "out of the box" solution and quite a lot of work, but is saves buying a new scanner (and I am after all Dutch)!
    Probably the virtual XP machine delivered by MS will do the trich as well, but this really doesn't work on Home Premium. You need professional for that (I tried really hard, but failed. After this I used VMWare)
    New Friend:
ALONG instructions Windows Vista, Windows 7 not to serve.
But with ubuntu (live version available without installation) I was able to use it in the first, without installing any software from the application of scanning.
Posted on Aug 10, 2010
4 Suggested Answers
SOURCE:
nonontech
  • 4737 Answers
SOURCE: looking for the driver for hp scanjet 2200c in the
It seems there's no drivers for your scanner which supports Windows 7. I have tried with the HP and couldn't find any driver compatible with Windows 7 related to your model. You can refer to the link provided below, or you can request from the HP : http://bit.ly/aTJrtM This is the shortened Url.. Good luck..
Posted on May 10, 2010
Testimonial: "Thank you for your time."
SOURCE: HP ScanJet 2200C on vista
This blog discusses how to get your scanners working in Vista:
http://www.vistax64.com/vista-print-fax-scan/21348-re-drivers-hp-scanjet-2200c-scanner.html
Posted on Feb 04, 2008
  • 6006 Answers
SOURCE: Scanjet 2200c under Windows 7
HP does not have a driver for this scanner with either Vista or Windows 7. One workaround is available in Windows 7 Pro or Ultimate. You can set up the XP mode and install the scanner within the virtual computer. Scanned files may need to be put on an external drive to transfer them between the two "computers".
I hope this helps.
Posted on Jan 10, 2010
Hi, I need a driver for may HP ScanJet 2200C to work with Win7 64bit, is there any? Regards,
You can find drivers for HP 2200C Scanjet scanner for Win 7 and 8 from www.hamrick.com. Its working with watermark in free edition otherwise you have to buy the licence.
Regards
Mukesh
Sep 24, 2011 | HP ScanJet 2200C Flatbed Scanner
MY SCANNER IS HP SCANJET 2200C AND MY OPERATING SYSTEM IS WIN 7 HOW CAN I ISNTALL MY SCANNER ? THANKS
Hello:
Try going to Hp solutions website and download the updated drivers for windows 7. Usually the drivers come with windows operating system. But you may need a new driver for the unit to work correctly.
Sep 09, 2011 | HP ScanJet 2200C Flatbed Scanner
From where can i optain windows 7 drivers for HP scanjet 2200c
That one does not support windows 7 but you can install the driver for xp and it might work first uninstal all drivers for the scanner do this go to systems and hardware remove all the old drivers and then install the driver that is most recent like xp or vista,
Good Luck
Chris Thrash
B52Computers
Jan 10, 2011 | HP ScanJet 2200C Flatbed Scanner
Looking for the driver for hp scanjet 2200c in the windows 7 setup.
May 10, 2010 | HP ScanJet 2200C Flatbed Scanner
I cannot get the drivers for my HP Scanjet 2200c. It worked in XP but now I dont have the disk. I have tried the old XP drivers and they dont work. There are no updates available under windows update or HP...
Below is the link where you can go and download the drivers and firmware for the HP Scanjet 2200C Flatbed scanner.
Click Here to download
Please let me know if you have any further questions or concerns.
Thanks.
Apr 16, 2010 | HP ScanJet 2200C Flatbed Scanner
I hope this helps.
Jan 10, 2010 | HP ScanJet 2200C Flatbed Scanner
How to set up and use
What is your computer's operating system? » Microsoft Windows Vista » Microsoft Windows Vista (64-bit) » Microsoft Windows XP » Microsoft Windows 2000 » Microsoft Windows ME » Microsoft Windows 98 » Microsoft Windows 95 » Microsoft Windows NT 4.0
Oct 06, 2007 | HP ScanJet 2200C Flatbed Scanner
HP ScanJet 2200C Flatbed Scanner Logo
33,675 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
