Question about Sony CLIE PEG-NR70V Handheld
Will not turn off will not reset - Sony CLIE PEG-NR70V Handheld
  • Anonymous Mar 22, 2008
    reset, differant plugs, turn off for an hour and try again
I may have something that works for dell axim x30
if the unit refuses to power on, (and it is out of waranty)<--- only if and only if.
then pull back away and unplug the battery for 10-15 seconds)
someone else suggested it here. it worked for me.
YOU WILL MEED A GOOD LIGHT AND TWEEZERS.
BE GENTLE WITH IT<--VERY IMPORTANT
Posted on Jun 14, 2008
    Problem Solver:
  • 12 Answers
If you're not too squeamish with disassembly, open the back case and unplug the battery for about 30 seconds. That should force the RAM to clear if a reset doesn't work.
Posted on May 13, 2008
How do I reset service indicator on a vauxhall astra 2013?
• Turn Ignition Off
• Hold Trip Reset In
• Turn Ignition On
• Still Holding Trip Reset wait for three dashes
• Turn off Ignition
• Turn on Ignition to confirm
Oct 17, 2014 | Cars & Trucks
What is the correct reset for Yamaha P 85 Digital Piano?
Reset Instructions:
1) Try a partial reset by holding down the last white key while turning the unit ON.
2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
Jan 03, 2014 | Yamaha P85 88Key Portable Digital Piano
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
Ink absorber is full
Resetting your canon printer will solve your problem. follow these instruction to successfully reset and fix your problem
1. Turn off your printer
2. Hold the Stop/Reset button then press the On/Off button
3. While holding Stop/Reset and On/Off button press Stop/Reset button, it will go to service mode.
4. On Service mode press Stop/Reset 4 times (this will reset ink absorber problem)
5. Turn off and then turn on your printer.
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Maintenance Lamp
Here's how you reset your maintenance light.
To reset the light,
Turn the ignition on
Make sure the odometer displays "ODO"
1.Turn the key off
2.Press and hold down the same button you use to get to "ODO"
3.Turn the key back to ON ( while still holding down the button)
4.Hold the button in until all the flashing lines on the odometer go away and the bunch of "000000" shows up and the maint reset light will turn off.
Your'e done.
If this doesn't work, you would have to try it on "trip A" instead of "ODO".
Oct 03, 2009 | 2006 Toyota Tundra
How do i switch off service now light on my vw golf 53 plate
Courtesy www.synthetic-direct.ca:
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button “A” located below the speedometer. Turn off the ignition while holding the button. “OEL” will display on the indicator. Press and hold the lower digital clock reset button or the analog clock reset button “B” until five dashes appear in the display.
If needed, next press the odometer reset button until IN 01 is displayed and then press the clock reset button until five dashes appear. If needed, next press the odometer reset button until IN 02 is displayed and then press the clock reset button until five dashes appear.
To exit reset mode, turn ignition switch on and when IN 01 appears, turn ignition off.
Jul 24, 2009 | Volkswagen Golf Cars & Trucks
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Dec 02, 2008 | HP DeskJet 5550 InkJet Printer
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Sony CLIE PEG-NR70V Handheld Logo
77 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
